[Qgis-user] Determining the Name of the Current Style File of a QGIS layer
    Bill Casey
    wtcasey at wtcasey.net
    Fri Apr 12 15:07:10 PDT 2024
Thank you, Raymond, for your clear and logical explanation.
When I think about it a bit more, it is obvious that having a style file
name attached to a layer's properties doesn't make sense.  I could apply
a style file to a layer and have its name recorded as a layer property.
However, I could then edit the layer's style, but not save the change to
the original style file.  Hence the style file name recorded in the
layer properties would no longer be valid.
Bill Casey
More information about the QGIS-User
