[Qgis-user] [QGIS-Developer] A load of updates in OSGeo4W
Alexandre Neto
senhor.neto at gmail.com
Mon Apr 15 01:52:59 PDT 2024
I will run the manual tests both for qgis.ltr.full and qgis-full.
Thanks,
Alex Neto
Sent with Shortwave <https://www.shortwave.com?utm_medium=email&utm_content=signature&utm_source=c2VuaG9yLm5ldG9AZ21haWwuY29t>
On Sun Apr 14, 2024, 11:02 PM GMT, Jürgen E. Fischer via QGIS-Developer <mailto:qgis-developer at lists.osgeo.org> wrote:
> Hi there,
> I just uploaded an update to OSGeo4W. It is basically a rebuild of everything
> with a newer compiler (Visual C++ 2022) and updates of almost all versions.
> The update should work cleanly and cause no visual changes.
> The main change is the move from Python 3.9.18 to 3.12.3. But there's also an
> update to Qt 5.15.13, OpenSSL 3. Qt6 was also added enabling an experimental
> build of QGIS master with Qt6. Based on that there is also an experimental
> version of QField.
> GDAL and PROJ also were updated to the latest version.
> The legacy GRASS 7 was removed because it doesn't support Python 3.12. GRASS 8
> was already available and QGIS switch to it long before this update.
> Please test and report.
> Jürgen
> More details in the commit message:
> A load of updates (fixes #788, #810, #816, #819, #820, #823, closes jef-n/OSGeo4W#21, refs qgis/QGIS#54491, qgis/QGIS#56499)
> Highlights:
> Switched to Visual Studio 2022
> Qt6 6.6.3, PyQt6 6.6.1
> Qt5 5.15.13, PyQt5 5.15.10
> Python 3.12.3
> OpenSSL 3.0.13
> PROJ 9.4.0
> GDAL 3.8.5
> qgis-qt6-dev based on Qt6 next to qgis-dev based on Qt5
> experimental QField based on Qt6 / qgis-qt6-dev
> Details:
> Removed:
> libjpeg (already replaced with libjpeg-turbo earlier)
> python3-clcache (replaced by ccache)
> python3-pyuv (dependency of python3-clcache)
> Updated:
> apache 2.4.52 -> 2.4.58
> arrow-cpp 7.0.0 -> 15.0.2
> boost 1.74.0 -> 1.84.0
> brotli 1.0.9 -> 1.1.0
> curl 8.4.0 -> 8.6.0
> draco 1.5.6 -> 1.5.7
> exiv2 0.27.3 -> 0.28.2
> expat 2.2.10 -> 2.6.2
> ffmpeg 5.1 -> 6.1.1
> freetype 2.10.2 -> 2.13.2
> gdal 3.8.4 -> 3.8.5
> gpsbabel 1.8.0 -> 1.9.0
> grass 7.8.8 -> 8.3.2
> grass8 8.3.2 -> 99 (transitional; depends on grass)
> gsl 2.6 -> 2.7.1+
> hdf4 4.2.16 -> 4.3.0
> hdf5 1.14.0 -> 1.14.3
> kealib 1.4.14 -> 1.5.3
> lerc 3.0 -> 4.0.0
> libharu 2.3.0 -> 2.4.4
> libiconv 1.16 -> 1.17
> libjpeg-turbo 2.0.7-esr -> 3.0.2
> libjxl 0.8.1 -> 0.10.2
> libmysql 8.0.21 -> 8.2.0
> libosmium-devel 2.18.0 -> 2.20.0
> libpng 1.6.37 -> 1.6.43
> libtiff 4.5.1 -> 4.6.0
> libxml2 2.9.10 -> 2.12.5
> libxslt 1.1.34 -> 1.1.39
> libzip 1.7.3 -> 1.10.1
> lua 5.4.4 -> 5.4.6
> lz4 1.9.3 -> 1.9.4
> minizip-ng-devel 3.0.2 -> 4.0.4
> node 16.14.0 -> 20.11.1
> oci 19.11 -> 21.13
> ogdi 4.1.0 -> 4.1.1
> opencl 2.0.10 -> 2023.12.14
> openfyba-devel 20150103 -> 20240408
> openjpeg 2.4.0 -> 2.5.2
> openssl 1.1.1w -> 3.0.13
> osm2pgsql 1.8.1 -> 1.11.0
> osmium 1.15.0 -> 1.16.0
> pdal 2.6.0 -> 2.6.3
> poppler 23.07.0 -> 24.04.0
> proj 9.3.1 -> 9.4.0
> proj-data 1.16 -> 1.17
> python3 3.9.18 -> 3.12.3
> protobuf-devel 3.13.0 -> 25.3
> qca 2.3.1 -> 2.3.8
> qscintilla 2.13.4 -> 2.14.1
> qt5 5.15.3 -> 5.15.13
> qtkeychain 0.13.2 -> 0.14.2
> qwc2 20220311-671a6e7 -> 20240408-3d95409
> qwt 6.1.6 -> 6.2.0
> saga 7.8.2 -> 9.3.1
> saga9 9.2.0 -> 99 (transitional; depends on saga)
> snappy-devel 1.1.9 -> 1.1.10
> spdlog-devel 1.10.0 -> 1.13.0
> sqlite3 3.41.1 -> 3.45.1
> swig 4.0.2 -> 4.2.1
> thrift 0.16.0 -> 0.20.0
> transifex-cli 1.6.5 -> 1.6.10
> utf8proc 2.7.0 -> 2.9.0
> wxwidgets 3.2.1 -> 3.2.4
> xerces-c 3.2.3 -> 3.2.5
> xz 5.2.5 -> 5.4.5
> yarnpkg 1.22.17 -> 1.22.21
> zlib 1.2.12 -> 1.3.1
> zstd 1.4.5 -> 1.5.5
> Updated Python extensions:
> python3-access 1.1.1 -> 1.1.9
> python3-affine 2.3.0 -> 2.4.0
> python3-alabaster 0.7.12 -> 0.7.16
> python3-argon2-cffi 20.1.0 -> 23.1.0
> python3-atomicwrites 1.4.0 -> 1.4.1
> python3-attrdict 2.0.1 -> python3-attrdict3 2.0.2
> python3-attrs 20.2.0 -> 23.2.0
> python3-autopep8 2.0.1 -> 2.1.0
> python3-babel 2.8.0 -> 2.14.0
> python3-backports.entry-points-selectable 1.1.0 -> 1.3.0
> python3-beautifulsoup4 4.9.3 -> 4.12.3
> python3-bleach 3.2.1 -> 6.1.0
> python3-certifi 2020.6.20 -> 2024.2.2
> python3-cffi 1.14.3 -> 1.16.0
> python3-cftime 1.2.1 -> 1.6.3
> python3-chardet 3.0.4 -> 5.2.0
> python3-click 7.1.2 -> 8.1.7
> python3-cligj 0.7.0 -> 0.7.2
> python3-colorama 0.4.4 -> 0.4.6
> python3-coverage 5.3 -> 7.4.4
> python3-cycler 0.10.0 -> 0.12.1
> python3-decorator 4.4.2 -> 5.1.1
> python3-defusedxml 0.6.0 -> 0.7.1
> python3-distlib 0.3.2 -> 0.3.8
> python3-docutils 0.16 -> 0.20.1
> python3-entrypoints 0.3 -> 0.4
> python3-esda 2.3.1 -> 2.5.1
> python3-exifread 2.3.2 -> 3.0.0
> python3-filelock 3.0.12 -> 3.13.3
> python3-fiona 1.9.5 -> 1.9.6
> python3-fonttools 4.28.5 -> 4.51.0
> python3-future 0.18.2 -> 1.0.0
> python3-gdal 3.8.4 -> 3.8.5
> python3-geoalchemy2 0.12.5 -> 0.14.7
> python3-geographiclib 1.50 -> 2.0
> python3-geopandas 0.14.1 -> 0.14.3
> python3-giddy 2.3.3 -> 2.3.5
> python3-greenlet 1.1.1 -> 3.0.3
> python3-h5py 3.8.0 -> 3.10.0
> python3-httplib2 0.18.1 -> 0.22.0
> python3-idna 2.10 -> 3.6
> python3-imagesize 1.2.0 -> 1.4.1
> python3-importlib-metadata 2.0.0 -> 7.1.0
> python3-inequality 1.0.0 -> 1.0.1
> python3-iniconfig 1.1.1 -> 2.0.0
> python3-ipykernel 5.3.4 -> 6.29.4
> python3-ipython 7.18.1 -> 8.23.0
> python3-ipywidgets 7.5.1 -> 8.1.2
> python3-isort 5.12.0 -> 5.13.2
> python3-jedi 0.17.2 -> 0.19.1
> python3-jinja2 3.1.2 -> 3.1.3
> python3-joblib 0.17.0 -> 1.3.2
> python3-jsonschema 3.2.0 -> 4.21.1
> python3-jupyter-client 6.1.7 -> 8.6.1
> python3-jupyter-console 6.2.0 -> 6.6.3
> python3-jupyter-core 4.6.3 -> 5.7.2
> python3-jupyterlab-pygments 0.1.2 -> 0.3.0
> python3-kiwisolver 1.2.0 -> 1.4.5
> python3-libpysal 4.3.0 -> 4.10
> python3-llvmlite 0.34.0 -> 0.42.0
> python3-lxml 4.6.2 -> 5.2.1
> python3-mapclassify 2.3.0 -> 2.6.1
> python3-markupsafe 1.1.1 -> 2.1.5
> python3-matplotlib 3.5.1 -> 3.8.4
> python3-mgwr 2.1.2 -> 2.2.1
> python3-mistune 0.8.4 -> 3.0.2
> python3-mock 4.0.2 -> 5.1.0
> python3-mod-wsgi 4.9.0 -> 5.0.0
> python3-mpmath 1.1.0 -> 1.3.0
> python3-munch 2.5.0 -> 4.0.0
> python3-nbclient 0.5.1 -> 0.10.0
> python3-nbconvert 6.0.7 -> 7.16.3
> python3-nbformat 5.0.8 -> 5.10.4
> python3-nest-asyncio 1.4.2 -> 1.6.0
> python3-netcdf4 1.6.3 -> 1.6.5
> python3-networkx 2.5 -> 3.3
> python3-nltk 3.5 -> 3.8.1
> python3-nose2 0.9.2 -> 0.14.1
> python3-notebook 6.1.4 -> 7.1.2
> python3-numba 0.51.2 -> 0.59.0
> python3-numpy 1.24.1 -> 1.26.4
> python3-openpyxl 3.0.9 -> 3.1.2
> python3-osmium 3.4.1 -> 3.7.0
> python3-owslib 0.29.2 -> 0.30.0
> python3-packaging 20.4 -> 24.0
> python3-pandas 2.0.2 -> 2.2.1
> python3-pandocfilters 1.4.3 -> 1.5.1
> python3-parso 0.8.0 -> 0.8.4
> python3-patsy 0.5.1 -> 0.5.6
> python3-pbr 5.5.1 -> 6.0.0
> python3-pdal-plugins 1.2.1 -> 1.3.0
> python3-pillow 10.0.1 -> 10.3.0
> python3-pirogue 1.2.5 -> 1.4.2
> python3-platformdirs 2.0.2 -> 4.2.0
> python3-plotly 4.12.0 -> 5.20.0
> python3-pluggy 0.13.1 -> 1.4.0
> python3-pointpats 2.2.0 -> 2.4.0
> python3-prometheus-client 0.8.0 -> 0.20.0
> python3-prompt-toolkit 3.0.8 -> 3.0.43
> python3-psycopg 3.1.9 -> 3.1.18
> python3-psycopg2-binary 2.9.3 -> 2.9.9
> python3-pum 0.9.12 -> 0.10.0
> python3-py 1.9.0 -> 1.11.0
> python3-pybind11 2.6.2 -> 2.12.0
> python3-pycparser 2.20 -> 2.22
> python3-pygments 2.7.2 -> 2.17.2
> python3-pymemcache 3.4.0 -> 4.0.0
> python3-pyodbc 4.0.30 -> 5.1.0
> python3-pyopengl 3.1.5 -> 3.1.7
> python3-pyparsing 2.4.7 -> 3.1.2
> python3-pyqt-builder 1.10.3 -> 1.16.0
> python3-pyqt5 5.15.4 -> 5.15.10
> python3-pyqt5-sip 12.8.1 -> 12.13.0
> python3-pyqtwebengine 5.15.5 -> 5.15.6
> python3-pyrsistent 0.17.3 -> 0.20.0
> python3-pysal 2.3.0 -> 24.1
> python3-pytest 6.1.2 -> 8.1.1
> python3-pytest-cov 2.10.1 -> 5.0.0
> python3-python-dateutil 2.8.1 -> 2.9.0.post0
> python3-pythonqwt 0.8.3 -> 0.12.1
> python3-pytz 2023.3 -> 2024.1
> python3-pywinpty 0.5.7 -> 2.0.13
> python3-pyyaml 5.3.1 -> 6.0.1
> python3-pyzmq 19.0.2 -> 25.1.2
> python3-qscintilla 2.13.4 -> 2.14.1
> python3-qtconsole 4.7.7 -> 5.5.1
> python3-qtpy 1.9.0 -> 2.4.1
> python3-quantecon 0.4.8 -> 0.7.2
> python3-rasterstats 0.15.0 -> 0.19.0
> python3-regex 2020.10.28 -> 2023.12.25
> python3-reportlab 4.0.4 -> 4.1.0
> python3-requests 2.24.0 -> 2.31.0
> python3-retrying 1.3.3 -> 1.3.4
> python3-rtree 0.9.4 -> 1.2.0
> python3-scikit-learn 0.23.2 -> 1.4.1.post1
> python3-scipy 1.10.1 -> 1.13.0
> python3-seaborn 0.11.0 -> 0.13.2
> python3-segregation 1.4.0 -> 2.5
> python3-send2trash 1.5.0 -> 1.8.3
> python3-setuptools 67.6.0 -> 69.2.0
> python3-shapely 2.0.2 -> 2.0.3
> python3-simplejson 3.17.2 -> 3.19.2
> python3-sip 6.1.1 -> 6.8.3
> python3-six 1.15.0 -> 1.16.0
> python3-snowballstemmer 2.0.0 -> 2.2.0
> python3-soupsieve 2.0.1 -> 2.5
> python3-spaghetti 1.5.3 -> 1.7.5.post1
> python3-spglm 1.0.8 -> 1.1.0
> python3-sphinx 3.3.0 -> 7.2.6
> python3-splot 1.1.3 -> 1.1.5.post1
> python3-spreg 1.1.2.post1 -> 1.4.2
> python3-sqlalchemy 1.4.42 -> 2.0.29
> python3-statsmodels 0.14.0 -> 0.14.1
> python3-sympy 1.6.2 -> 1.12
> python3-terminado 0.9.1 -> 0.18.1
> python3-testpath 0.4.4 -> 0.6.0
> python3-threadpoolctl 2.1.0 -> 3.4.0
> python3-tobler 0.4.0 -> 0.11.2
> python3-toml 0.10.1 -> 0.10.2
> python3-torch 2.2.1 -> 2.2.2
> python3-tornado 6.0.4 -> 6.4
> python3-tqdm 4.51.0 -> 4.66.2
> python3-traitlets 5.0.5 -> 5.14.2
> python3-typing-extensions 4.5.0 -> 4.11.0
> python3-tzdata 2023.3 -> 2024.1
> python3-urllib3 1.25.11 -> 2.2.1
> python3-virtualenv 20.5.0 -> 20.25.1
> python3-wcwidth 0.2.5 -> 0.2.13
> python3-wheel 0.35.1 -> 0.43.0
> python3-widgetsnbextension 3.5.1 -> 4.0.10
> python3-xlrd 1.2.0 -> 2.0.1
> python3-zipp 3.4.0 -> 3.18.1
> Just rebuilt with VS2022:
> api-ms-win-core-path-HACK 0.0.1
> avce00 2.0.0
> base 1.0.0
> bzip2-devel 1.0.8
> cairo 1.17.2
> entwine 3.0.0
> fcgi 2.4.2
> freexl 2.0.0
> geos 3.12.1
> gs 10.02.1
> icu 67.1
> imposm3 0.11.1
> laszip 3.4.3
> libgeotiff 1.7.1
> libkml-devel 1.3.0
> liblas 1.8.1
> libpq 16.2
> librttopo 1.1.0
> libspatialindex 1.9.3
> libspatialite 5.1.0
> libwebp 1.3.2
> mod_fcgid 2.3.10
> netcdf 4.9.2
> odbc-cpp-wrapper 1.1
> pcraster 4.4.1
> protozero-devel 1.7.1
> qgis 3.36.1
> qgis-ltr 3.34.5
> qtwebkit 5.212.0-alpha4
> qwc-services 1.3.4
> setup 1.1.2
> shell 99.0.0
> szip 2.1.1
> tiledb 2.8.2
> wingetopt-devel 1.00
> Repackaged/rebuilt for Python 3.12
> python3-async-generator 1.10
> python3-backcall 0.2.0
> python3-click-plugins 1.1.1
> python3-descartes 1.1.0
> python3-et-xmlfile 1.1.0
> python3-ipython-genutils 0.2.0
> python3-jupyter 1.0.0
> python3-mapproxy 2.0.2
> python3-mypy-extensions 1.0.0
> python3-pdal 3.2.3
> python3-pickleshare 0.7.5
> python3-pip 24.0
> python3-ply 3.11
> python3-pypdf2 3.0.1
> python3-pypiwin32 223
> python3-pyproj 3.6.1
> python3-pypubsub 3.3.0
> python3-pyserial 3.5
> python3-pytoml 0.1.21
> python3-pywin32 306
> python3-rasterio 1.3.9
> python3-remotior-sensus 0.3.5
> python3-snuggs 1.4.7
> python3-spint 1.0.7
> python3-spvcm 0.3.0
> python3-tomli 2.0.1
> python3-webencodings 0.5.1
> python3-wxpython 4.2.1
> python3-xlwt 1.3.0
> Added:
> grass7 99 (transitional; depends on grass(8); grass 7 doesn't support python 3.12)
> podofo 0.10.3
> qca-qt6 2.3.8
> qgis-qt6-dev (master based on Qt6)
> qscintilla-qt6 2.14.1
> qt6 6.6.3
> qtkeychain-qt6 0.14.2
> qwt-qt6 6.2.0
> uriparser-devel 0.9.7
> saga7 7.9.1 (old saga, just in case)
> qfield-dev 3.2.2 (experimental; depends on very heady qgis-qt6-dev; TODO split the latter to minimize qfield dependencies)
> poly2tri-devel 20240411 (qfield dependency)
> zxing-cpp-devel 2.2.1 (qfield dependency)
> Added python extensions:
> python3-anyio 4.3.0
> python3-argon2-cffi-bindings 21.2.0
> python3-asttokens 2.4.1
> python3-async-lru 2.0.4
> python3-charset-normalizer 3.3.2
> python3-comm 0.2.2
> python3-contourpy 1.2.1
> python3-debugpy 1.8.1
> python3-deprecation 2.1.0
> python3-duckdb 0.10.1
> python3-executing 2.0.1
> python3-fastjsonschema 2.19.1
> python3-fsspec 2024.3.1
> python3-h11 0.14.0
> python3-httpcore 1.0.5
> python3-httpx 0.27.0
> python3-json5 0.9.24
> python3-jsonschema-specifications 2023.12.1
> python3-jupyter-events 0.10.0
> python3-jupyter-lsp 2.2.5
> python3-jupyter-server 2.13.0
> python3-jupyter-server-terminals 0.5.3
> python3-jupyterlab 4.1.5
> python3-jupyterlab-server 2.26.0
> python3-jupyterlab-widgets 3.0.10
> python3-matplotlib-inline 0.1.6
> python3-maturin 1.5.1
> python3-momepy 0.7.0
> python3-notebook-shim 0.2.4
> python3-overrides 7.7.0
> python3-pathspec 0.12.1
> python3-psutil 5.9.8
> python3-psycopg2 2.9.9
> python3-pulp 2.8.0
> python3-pure-eval 0.2.2
> python3-pyarrow 15.0.2
> python3-pycodestyle 2.11.1
> python3-pyqt6 6.6.1
> python3-pyqt6-qscintilla 2.14.1
> python3-pyqt6-sip 13.6.0
> python3-python-json-logger 2.0.7
> python3-referencing 0.34.0
> python3-rfc3339-validator 0.1.4
> python3-rfc3986-validator 0.1.1
> python3-rpds-py 0.18.0
> python3-sniffio 1.3.1
> python3-sphinxcontrib-applehelp 1.0.8
> python3-sphinxcontrib-devhelp 1.0.6
> python3-sphinxcontrib-htmlhelp 2.0.5
> python3-sphinxcontrib-jsmath 1.0.1
> python3-sphinxcontrib-qthelp 1.0.7
> python3-sphinxcontrib-serializinghtml 1.1.10
> python3-spopt 0.6.0
> python3-stack-data 0.6.3
> python3-tenacity 8.2.3
> python3-tinycss2 1.2.1
> python3-websocket-client 1.7.0
> Other changes:
> * acceptable licenses updated
> * switch to VS2022
> * add bootstrap.cmd to
> * invoke installation of cygwin base,
> * clone the repo
> * build everything
> * build process installs necessary tools if necessary
> * vs2022
> * debug tools (for dbghelp.dll)
> * cmake
> * ninja
> * ccache (supports msvc now)
> * enables long paths on build (for Qt6 / webengine / chromium)
> * cleanups
> * PACKAGES added to package.sh to list produced packages
> * devenv replaced with msbuild
> * Update of ECWJP2SDKSetup_5.5.0.2268-Update4-Windows.zip not automatically
> downloadable anymore (place in src/gdal/osgeo4w/gdaldeps and
> src/gdal-dev/osgeo4w/gdaldeps)
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden https://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240415/ffb482f4/attachment.htm>
More information about the QGIS-User
