[Qgis-user] Map Corner Coordinates
Alanna Mitchell A.Mitchell at aquafact.ie
Mon Apr 15 03:13:00 PDT 2024
Dear QGIS community,
I am attempting to get the coordinate intersects of my map corners to display in Print Layout/Composer (i.e., N and W coordinates). The exact directions were: 'For geo-referencing purposes labelled coordinate intersects should be shown in all four corners of the map'. There does not seem to be an option for this in QGIS (I have found a few in ARC). I have found dynamic text in the Print Layout (Add Items - Add Dynamic Text - Map Properties) and one can see X minimum, X maximum, Y etc. I am not sure what these are or if they are relevant to me finding the map corner coordinates.
I also found the plugin Map Corner coordinates. But this seems to only work for the main map viewer, and I can't get this to align exactly with my Print Layout to ensure these coordinates are exactly the same.
If there was even a mathematically method, I would be more than partial to using that even. I appreciate any and all help in these matters. Thank you in advance.
Kind Regards,
Alanna
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240415/a87471d9/attachment.htm>
More information about the QGIS-User mailing list
