[Qgis-user] Map Corner Coordinates
Andreas Neumann a.neumann at carto.net
Mon Apr 15 04:57:30 PDT 2024
Hi Alanna,
It depends a bit on what you want to do.
There are map grids that you can use to label the edges of a map.
Or you can use a label with an expression. Here is one expression to
help you get started:
with_variable(
     'mapextent',
     map_get(item_variables('Map1'),'map_extent'),
     round(x_min(@mapextent)) || ' - ' || round(x_max(@mapextent))
This gets the map extent of the map with the ID "Map1" (you need to set
the ID accordingly). Using the item_variables() data structure you can
get hold of the first map and then query one or more of the attributes
of a referenced item in a layout.
https://docs.qgis.org/3.34/en/docs/user_manual/expressions/functions_list.html#variables
gives you a list of available variables - but it depends of the
expression scope you are currently in.
Hope this helps you to get started.
Andreas
On 2024-04-15 12:13, Alanna Mitchell via QGIS-User wrote:
> Dear QGIS community,
> I am attempting to get the coordinate intersects of my map corners to
> display in Print Layout/Composer (i.e., N and W coordinates). The exact
> directions were: 'For geo-referencing purposes labelled coordinate
> intersects should be shown in all four corners of the map'. There does
> not seem to be an option for this in QGIS (I have found a few in ARC).
> I have found dynamic text in the Print Layout (Add Items - Add Dynamic
> Text - Map Properties) and one can see X minimum, X maximum, Y etc. I
> am not sure what these are or if they are relevant to me finding the
> map corner coordinates.
> I also found the plugin Map Corner coordinates. But this seems to only
> work for the main map viewer, and I can't get this to align exactly
> with my Print Layout to ensure these coordinates are exactly the same.
> If there was even a mathematically method, I would be more than partial
> to using that even. I appreciate any and all help in these matters.
> Thank you in advance.
> Kind Regards,
> Alanna
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240415/b7046bbd/attachment.htm>
More information about the QGIS-User mailing list
