[Qgis-user] Map Corner Coordinates
Richard McDonnell richard.mcdonnell at opw.ie
Mon Apr 15 05:14:01 PDT 2024
Hi Alanna,
In addition to Andreas message…
If a table with the extents (Lower Left and Upper Right) is what you are looking for then something similar to the below is an option..
[cid:image001.png at 01DA8F36.C6979600]
You could also, conceivably, use the expressions in text boxes.
Hope that helps,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
Flood Risk Management - Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Andreas Neumann via QGIS-User
Sent: 15 April 2024 12:58
To: Alanna Mitchell <A.Mitchell at aquafact.ie>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Map Corner Coordinates
Hi Alanna,
It depends a bit on what you want to do.
There are map grids that you can use to label the edges of a map.
Or you can use a label with an expression. Here is one expression to help you get started:
with_variable(
    'mapextent',
    map_get(item_variables('Map1'),'map_extent'),
    round(x_min(@mapextent)) || ' - ' || round(x_max(@mapextent))
This gets the map extent of the map with the ID "Map1" (you need to set the ID accordingly). Using the item_variables() data structure you can get hold of the first map and then query one or more of the attributes of a referenced item in a layout.
https://docs.qgis.org/3.34/en/docs/user_manual/expressions/functions_list.html#variables gives you a list of available variables - but it depends of the expression scope you are currently in.
Hope this helps you to get started.
Andreas
On 2024-04-15 12:13, Alanna Mitchell via QGIS-User wrote:
Dear QGIS community,
I am attempting to get the coordinate intersects of my map corners to display in Print Layout/Composer (i.e., N and W coordinates). The exact directions were: 'For geo-referencing purposes labelled coordinate intersects should be shown in all four corners of the map'. There does not seem to be an option for this in QGIS (I have found a few in ARC). I have found dynamic text in the Print Layout (Add Items - Add Dynamic Text - Map Properties) and one can see X minimum, X maximum, Y etc. I am not sure what these are or if they are relevant to me finding the map corner coordinates.
I also found the plugin Map Corner coordinates. But this seems to only work for the main map viewer, and I can't get this to align exactly with my Print Layout to ensure these coordinates are exactly the same.
If there was even a mathematically method, I would be more than partial to using that even. I appreciate any and all help in these matters. Thank you in advance.
Kind Regards,
Alanna
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240415/5cc9b5d8/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240415/5cc9b5d8/attachment-0001.png>
More information about the QGIS-User mailing list
