[Qgis-user] Please help!
    Zoltan Szecsei
    zoltans at geograph.co.za
    Mon Apr 22 01:44:33 PDT 2024
I'm guessing the '2053' might be wrong.
You need to know if your DEM coords are +ve East and North, or +ve West
and South
If +ve E/N then try EPSG:102567
I forget which of the remaining 2 (2053 and 102487) Lo29 codes are left
or right handed, but you only have these 3 to try.
When your DEM lands in the correct place in South Africa, then worry
about re-projecting to UTM35S
HTH,
Zoltan
On 2024/04/22 10:32, Stefan Bogenhofer via QGIS-User wrote:
> Good day
> I am having some trouble in regards to georeferencing a DEM which I
> received. The CRS of the DEM is “EPSG:2053 - Hartebeesthoek94 / Lo29”
> but when I reproject the DEM to the desired projection “WGS84 / UTM
> zone 35S” it puts the DEM somewhere in Egypt although the correct
> position where it should be in my study area is located is in South
> Africa. I have tried assigning new coordinate systems to both my
> project, web image layer and the DEM but it simply does not want to
> reference it to the correct position. Any help would be much appreciated!
> Thank you
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Zoltan Szecsei GPrGISc 0031
Director, Geograph (Pty) Ltd.
GIS and Photogrammetric Services
Cape Town, South Africa.
Mobile: +27-83-6004028 (Signal, not WhatsApp)
         +974-5058-8729
         +36-20-4808362
www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240422/774cef0b/attachment.htm>
More information about the QGIS-User
