[Qgis-user] Please help!
Nigel Berjak - S3 Technologies nigel at s3.co.za
Tue Apr 23 00:58:14 PDT 2024
Hi
EPSG 102567 is for the North/East orientation of the South African
projection. 2053 is the West/South version. Most data should be relating
to the N/E option. If you look at the coordinates, in QGIS, where no
View CRS is set, then the coordinates are likely to be -3.xmil on the
Southing, depending on where you are in in SA, and the Easting will be
positive to the east of the 29° meridian and negative to the west.
I hope this helps.
Regards,
Nigel Berjak
S3 Technologies
Geographic Information Systems & Large Format Printing specialists
T: +27 33 3423681
F: +27 86 6721242
E: nigel at S3.co.za
Website: http://www.S3.co.za
Please consider the environment before printing this email.
On 2024-04-22 10:44, Zoltan Szecsei via QGIS-User wrote:
> Hi,
> I'm guessing the '2053' might be wrong.
> You need to know if your DEM coords are +ve East and North, or +ve West
> and South
> If +ve E/N then try EPSG:102567
> I forget which of the remaining 2 (2053 and 102487) Lo29 codes are left
> or right handed, but you only have these 3 to try.
> When your DEM lands in the correct place in South Africa, then worry
> about re-projecting to UTM35S
> HTH,
> Zoltan
> On 2024/04/22 10:32, Stefan Bogenhofer via QGIS-User wrote:
>> Good day
>> I am having some trouble in regards to georeferencing a DEM which I
>> received. The CRS of the DEM is "EPSG:2053 - Hartebeesthoek94 / Lo29"
>> but when I reproject the DEM to the desired projection "WGS84 / UTM
>> zone 35S" it puts the DEM somewhere in Egypt although the correct
>> position where it should be in my study area is located is in South
>> Africa. I have tried assigning new coordinate systems to both my
>> project, web image layer and the DEM but it simply does not want to
>> reference it to the correct position. Any help would be much
>> appreciated!
>> Thank you
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Zoltan Szecsei GPrGISc 0031
> Director, Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> Cape Town, South Africa.
> Mobile: +27-83-6004028 (Signal, not WhatsApp)
> +974-5058-8729
> +36-20-4808362
> www.geograph.co.za [1]
Links:
[1] http://www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240423/58e7ab3e/attachment.htm>
More information about the QGIS-User mailing list
