[Qgis-user] merging parts from various raster files
sibylle.stoeckli at gmx.ch
Tue Apr 30 06:10:13 PDT 2024
Hello Frank and Richard
I have 10-12 raster files (figure 1, .tif files), they all look the same and
cover the entire country with no definition of the biogeregions.
Second there is the shape file defining the biogeoregions (figure 2,
different colors).
* Probably I first need to extract the different biogeoregions out
from each raster file or define the linkage between the raster files the the
biogeoregions in the shape file. However, raster crop raster based on
layer mask extracts the entire mask (entire country) not the different
biogeoregions.
* Furter I may delete all the data in the raster files not needed:
e.g. in raster 1 just data on biogeo 1, but not the other biogeoregions, in
raster 2, data on biogeo 2, but not the other biogeregions. By doing so
there will be no overlap, as each raster file consists only one biogregions.
* I am not sure about the virtual raster, because it is not possible
to import .tif files.
* Then I may just use the merge function merging each bioregions.
Background: postprocessing of a model output. It was not possible to run the
model only for biogeoregion 1 (with input data from biogeoregion 1) ,
bioregion 2 (with input data from bioregion 2) etc. It was necessary to
model the entire country with input data from bioregion 1 etc.
Kind regards
Sibylle
Figure 1
Figure 2
Sent: Tuesday, April 30, 2024 1:48 PM
To: qgis-user at lists.osgeo.org; sibylle.stoeckli at gmx.ch
Subject: AW: [Qgis-user] merging parts from various raster files
Hello Sybille,
I am not sure if I understand your problem correctly. I assume, you have a
mosaic of raster files (that overlap) and you want to create a single raster
file for statistical analysis. In my opinion, the easiest way to achieve
that is to create a virtual raster (VRT) and either use that for stats or
create a new raster file from the VRT. You can find the tool in the
processing toolbox. With the tool you can even define the resolution, if
mixed, and how the VRT should be resampled.
HTH
Frank
https://docs.qgis.org/3.34/en/docs/user_manual/processing_algs/gdal/rastermi
scellaneous.html#build-virtual-raster
_____
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org
<mailto:qgis-user-bounces at lists.osgeo.org> > im Auftrag von Sibylle Stöckli
via QGIS-User <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
Gesendet: Dienstag, 30. April 2024 11:34
An: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
<qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org> >
Betreff: [Qgis-user] merging parts from various raster files
Dear community
I am working with QGIS 3.34 (Prizren) and would like to merge region 1 from
raster (.tif) file 1 and region 2 from raster file 2, and...
For sure I will need to use raster-miscellaneous-merge.
My question is related to the pre-processing of the input raster files.
- The 12 raster files all have the same coordinate system.
- The raster files are fully overlapping (the entire country).
- The region is not defined per se in the raster file, but in an additional
shape file (biogeo.shp).
- For sure I can carry out some zonal statistics using raster and shape
file, but to merge the regions I need all the pixels form a regions as input
file for the merging process. This process is more than just selecting
regions or cropping. Do you have any suggestions?
Kind regards
Sibylle
QGIS-User mailing list
QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240430/ddde1e41/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240430/ddde1e41/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240430/ddde1e41/attachment-0003.png>
More information about the QGIS-User
