[Qgis-user] merging parts from various raster files
Frank Broniewski
broniewski at a-a.lu
Tue Apr 30 04:47:52 PDT 2024
Hello Sybille,
I am not sure if I understand your problem correctly. I assume, you have a mosaic of raster files (that overlap) and you want to create a single raster file for statistical analysis. In my opinion, the easiest way to achieve that is to create a virtual raster (VRT) and either use that for stats or create a new raster file from the VRT. You can find the tool in the processing toolbox. With the tool you can even define the resolution, if mixed, and how the VRT should be resampled.
HTH
Frank
https://docs.qgis.org/3.34/en/docs/user_manual/processing_algs/gdal/rastermiscellaneous.html#build-virtual-raster
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> im Auftrag von Sibylle St?ckli via QGIS-User <qgis-user at lists.osgeo.org>
Gesendet: Dienstag, 30. April 2024 11:34
An: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Betreff: [Qgis-user] merging parts from various raster files
Dear community
I am working with QGIS 3.34 (Prizren) and would like to merge region 1 from
raster (.tif) file 1 and region 2 from raster file 2, and...
For sure I will need to use raster-miscellaneous-merge.
My question is related to the pre-processing of the input raster files.
- The 12 raster files all have the same coordinate system.
- The raster files are fully overlapping (the entire country).
- The region is not defined per se in the raster file, but in an additional
shape file (biogeo.shp).
- For sure I can carry out some zonal statistics using raster and shape
file, but to merge the regions I need all the pixels form a regions as input
file for the merging process. This process is more than just selecting
regions or cropping. Do you have any suggestions?
Kind regards
Sibylle
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240430/09fcbaa8/attachment.htm>
More information about the QGIS-User
