[Qgis-user] Point order in WKT export from polygon layer
Ian Turton
ijturton at gmail.com
Mon Aug 5 07:45:31 PDT 2024
I don't think the OGC specify a winding order, since WKT is explicit about
exterior and interior rings.
If you are looking at the unregulated geojson standard again I don't think
it specifies a winding order but it's been a while since I read that one
and I'm on my phone just now so I can't check. But it would be worth
looking at the RFC and pointing to the relevant section.
Ian
On Mon, 5 Aug 2024, 13:40 Reetz, Michael (NLPVW) via QGIS-User, <
qgis-user at lists.osgeo.org> wrote:
> Dear list,
> I’ve created a csv-file with coordinates in WKT-format by exporting a
> polygon layer with the “Save object as …”-option (“Objekte speichern als …”
> in the German QGIS version). I need this for querying data from GBIF via
> their API using JSON input. That has worked for the last years. But using
> the same JSON files this year gives an error because the point order is
> clockwise. I’ve found that according to the OGC standard the order should
> be counter clockwise for polygons and clockwise for excluded areas inside a
> polygon. It seems as if GBIF is following this standard now.
> Would it be possible to follow the OGC standard in the QGIS export, too?
> This would reduce the amount of rework after each export.
> Best regards
> Michael
> Mit freundlichen Grüßen
> Im Auftrag
> Michael Reetz
> Michael Reetz
> Datenbanken und Anwendungsentwicklung
> Nationalpark-Verwaltung Niedersächsisches Wattenmeer
> Virchowstr. 1 | 26382 Wilhelmshaven
> Tel.: +49 (0) 4421 911 291
> e-mail: michael.reetz at nlpvw.niedersachsen.de
> <michael.reetz at nlpv-wattenmeer.niedersachsen.de>
> Web: https://www.*nationalpark-wattenmeer.de
> <http://nationalpark-wattenmeer.de>*
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240805/1974d7c4/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240805/1974d7c4/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240805/1974d7c4/attachment-0001.png>
More information about the QGIS-User
