[Qgis-user] Install qgis-grass-plugin QGIS 3.38 and GRASS 8.4 on Ubuntu 22 jammy -
andreaerdna at libero.it
Tue Aug 6 02:27:07 PDT 2024
Amedeo Fadini amefad at gmail.com mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20Install%20qgis-grass-plugin%20QGIS%203.38%20and%20GRASS%208.4%0A%20on%20Ubuntu%2022%20jammy%20-&In-Reply-To=%3CCAKGZ3Gd%2B72FsEh%2BGRFD_gAdHQHPOC1KpCC%3D-PM_kQQd%2BJM5TBg%40mail.gmail.com%3E
Mon Aug 5 14:02:10 PDT 2024
> See also:
> https://github.com/qgis/QGIS/issues/49030
> https://www.qgis.org/resources/installation-guide/#note-4
> I'll give it a try with plain apt as it's sayng andreagiudiceandrea in the
fi rst link
Hi Amedeo,
I can confirm that just following the "Quickstart" installation guide available on the QGIS website [1], it is possible to currently install QGIS 3.38.1 (3d4177afc6), GRASS-GIS 7.8.7 (available in the default Ubuntu repository for 22.04 Jammy Jellyfish) and the QGIS GRASS plugin on Ubuntu 22.04.4.
If you instead add the ubuntugis-unstable ppa and use the https://qgis.org/ubuntugis repository, then you will currently face the error:
qgis-plugin-grass : Depends: grass832 but it is not installable
since the grass832 package is currently no longer available in ubuntugis-unstable (while I suppose it was instead available at the time that the latest qgis and qgis-plugin-grass packages were built).
In this case you need to use the https://qgis.org/ubuntugis-nightly-release repository instead of the https://qgis.org/ubuntugis repository in order to install qgis and qgis-plugin-grass built with the latest version of GRASS-GIS currently available in ubuntugis-unstable. This way, you will currently install the nightly debug build QGIS 3.38.1 (d6b0e3930f4) and GRASS-GIS 8.4.0.
Best regards.
Andrea Giudiceandrea
[1] https://www.qgis.org/resources/installation-guide/#quickstart
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240806/0f27d1da/attachment.htm>
More information about the QGIS-User
