[Qgis-user] SHP does not obey to change its SRC to a new one
Slade Beard slade.beard at ecothought.com
Sun Aug 11 14:48:57 PDT 2024
Allan,
"When I import a SHP to be place above a DEM under WGS 4326 it does not adjust to this SRC after assigning this code and even when it is reprojected remains with the original UTM-SRC."
I know its a basic principle but do you save the reprojected file as a new file? QGIS does not change the projection of the underlying file. You need to save the reprojected file into a new file in order to keep the changed projection.
Slade Beard
Director
EcoThought Pty Ltd
M 0411137692
ABN 15 125 372 821
"Warning:
The information contained in this email and any attached files is confidential to EcoThought Pty Ltd They may contain proprietary or copyright material or information that is subject to legal professional privilege. They are for the use of the intended recipient only. Any unauthorised viewing, use, disclosure, copying, alteration, storage or distribution of, or reliance on, this message is strictly prohibited. No part may be reproduced, adapted or transmitted without the written permission of the owner. If you have received this transmission in error, or are not an authorised recipient, please immediately notify the sender by return email, delete this message and all copies from your e-mail system, and destroy any printed copies. Receipt by anyone other than the intended recipient should not be deemed a waiver of any privilege or protection.
VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility.  It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer."
P
Please consider the environment before printing this e-mail
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> on behalf of Antonio Viscomi via QGIS-User <qgis-user at lists.osgeo.org>
Sent: Monday, 12 August 2024 7:37 AM
To: Allan López <allosa01 at gmail.com>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] SHP does not obey to change its SRC to a new one
Allan,
are you sure that the native shape's CRS is 4326? If so there isn't a reason for the overlay not works, otherwise you need to know the native shape's CRS then ensure to it's correctly define in shape's properties, if both of CRS (DEM and shape) are correctly defined the overlay outcome automatcally
Il dom 11 ago 2024, 02:09 Allan López via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> ha scritto:
Dear All,
Excuse my very basic question and please explain me the steps to solve this problem:
When I import a SHP to be place above a DEM under WGS 4326 it does not adjust to this SRC after assigning this code and even when it is reprojected remains with the original UTM-SRC. This problem comes from time to time.
Best,
Allan López
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240811/4a040dd1/attachment.htm>
More information about the QGIS-User mailing list
