[Qgis-user] Editing GPKG from network drive
Greg Troxel
gdt at lexort.com
Tue Aug 13 04:19:36 PDT 2024
Simon Gröchenig via QGIS-User <qgis-user at lists.osgeo.org> writes:
> Hi list,
> a project partner "sometimes" struggles to edit GPKGs that are saved
> on a network drive. Trying to modify the GPKG in QGIS results in the
> following error:
>> Provider errors: OGR error committing transaction:
>> sqlite3_exec(COMMIT) failed: disk I/O error
> No problems occur modifying the same GPKG when it is located on a
> local drive.
You didn't say what "network drive" means. My impression is that the
locking sqlite depends on doesn't necessarily work reliably in
Windows/CIFS. I don't expect I/O error, though.
You also didn't say whether you mean "on the same gigabit ethernet wired
lan" or "on a cell modem on the other side of the planet while the
file server holding a database is on a 9600 bps dialup modem"....
If you need a network-accessible database (which seems like a normal
thing to need!) then a good plan is likely to... install a
network-accessible database. I personally would install
postgresql/postgis, which is designed for both concurrent network access
and geospatial. (I'm using it on the same machine, because I don't have
your sharing requirements.)
> I found the following 8-year-old qgis-user thread:
> https://qgis-user.osgeo.narkive.com/bjrGqIjn/something-to-think-about-geopackage-and-wal
> Is this thread related to the disk I/O error?
> I would also like to ask if GPKGs or SQLite-DBs are still unsave to
> use from network drives!? Is there any current information about this
> somewhere?
> Best regards
> Simon
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
