[Qgis-user] GitHub workflow for plugin
    Renata Imai
    renataakemii at gmail.com
    Wed Aug 14 07:27:16 PDT 2024
Hi QGIS Community!
I want to set up a GitHub workflow to test if the QGIS plugin installation
is working on Windows and if the tests are passing.
I currently use this code, but it does not test the installation. Some
tests are failing under this Windows installation, but passing on
Ubuntu-latest.
Does anyone have a suggestion to overcome both installation and testing
issues?
Thanks a lot,
Renata Imai.
on:  [pull_request]
jobs:
  windows_test:
    runs-on: windows-latest
    steps:
      - uses: actions/checkout at v3
      - name: Install QGIS on Chocolatey
        uses: crazy-max/ghaction-chocolatey at v3
        with:
          args: install qgis-ltr -y --version 3.34.6
      - name: Plugin install
        shell: pwsh
        run: |
          $env:PATH="C:\Program Files\QGIS 3.34.6\bin;$env:PATH"
          $env:QGIS_PLUGIN_IN_CI=1
          python-qgis-ltr.bat -m pip install -r test/requirements-test.txt
          python-qgis-ltr.bat -m pytest test
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240814/e67ef392/attachment.htm>
More information about the QGIS-User
