[Qgis-user] Unable to open LAS file in QGIS
Gabriel De Luca
pablogabrieldeluca at gmail.com
Fri Aug 23 10:02:26 PDT 2024
As far as I understand, QGIS can convert the point cloud to the Entwine
Point Tile (EPT) format, or to the Cloud Optimized Point Cloud (COPC)
format, to represent it.
Yours is probably trying to convert the point cloud to EPT, which often
has problems with the names and sizes of the files it converts.
In that case, when loading the layer, you would see a directory with the
ept prefix appear in the same location as the LAS file, for example:
ept_point_cloud/.
Inside it, there should be two other directories with the tile files,
which do not seem to exist.
If you can confirm the existence of the ept_ directory, and the absence
of the tiles files within the generated subdirectories, then the conversion
to EPT has failed.
You can try to build the data with Entwine[1]. Once built, you will be
able to load the LAS file as a point cloud layer in QGIS to represent it.
[1] https://entwine.io/en/latest/quickstart.html#building-the-data
Regards,
Gabriel
El vie, 23 ago 2024 a la(s) 4:29 a.m., Loke Jian Munn via QGIS-User (
qgis-user at lists.osgeo.org) escribió:
> No, after zooming in still cannot see anything. Is it because of the size
> ? the point cloud size is about 1.6GB.
> And I also try to go Symbology and Statistic tab find out that seems like
> no attributes of the point cloud.
> *Loke Jian Munn*
> Information Technology (IT) Department
> *KUALA LUMPUR KEPONG BERHAD*
> Wisma Taiko,
> No. 1, Jalan S.P. Seenivasagam,
> 30000 Ipoh,Perak Darul Ridzuan,Malaysia
> *T : *+605 240 8000 (ext. 2443)
> [image: A close up of a sign Description automatically generated]
> <https://clicktime.symantec.com/15tpDKjABDCCmu4drBEZD?h=4-LzQeEUOcKmp7sCwswGafke694l_dZCDQJ4Rb8N8bc=&u=http://www.klk.com.my/>*[image:
> A close up of a sign Description automatically generated]*
> <https://clicktime.symantec.com/15tpJ9vSdpsoBqtZPjdhq?h=bX-LFOj0HrSJV_t-3L_WhMP3i5PRx5AtNBaHlI02C7k=&u=http://www.linkedin.com/company/klkberhad>
> *From:* DelazJ <delazj at gmail.com>
> *Sent:* Friday, 23 August, 2024 2:40 PM
> *To:* Christine Donkin <donkinc at bigpond.com>; Christine Donkin via
> QGIS-User <qgis-user at lists.osgeo.org>; Loke Jian Munn <jm.loke at klk.com.my>;
> *Subject:* Re: [Qgis-user] Unable to open LAS file in QGIS
> *CAUTION: **External Sender. Please do not click on links or open
> attachments from senders you do not trust.*
> Hi Loke,
> https://docs.qgis.org/3.34/en/docs/user_manual/working_with_point_clouds/point_clouds.html#symbology-properties
> <https://clicktime.symantec.com/15tpDNNZ8cqKjJkzQgxCd?h=6A_zbXAocvhlWaWCebUSKdNr3_q8ioWMu8bny0gIAn4=&u=https://docs.qgis.org/3.34/en/docs/user_manual/working_with_point_clouds/point_clouds.html%23symbology-properties>
> Regards,
> Harrissou
> Le 23 août 2024 07:37:44 GMT+02:00, Christine Donkin via QGIS-User <
> qgis-user at lists.osgeo.org> a écrit :
> Hi Loke
> Have you tried zooming in? My last files at 8ppsm don't display the
> points until about 1:1000 on a 1kmx1km tile.
> Cheers
> Christine
> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> on behalf of Loke
> Jian Munn via QGIS-User <qgis-user at lists.osgeo.org>
> *Sent:* Friday, August 23, 2024 1:33:45 pm
> *To:* qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
> *Subject:* [Qgis-user] Unable to open LAS file in QGIS
> Hi Team,
> I trying to add point cloud layer(las file) into QGIS but it appear like
> the screenshot below.
> May I know what causing this ?
> Thank you,
> *Loke Jian Munn*
> Wisma Taiko,
> DISCLAIMER: This email and any attachments are confidential and intended
> solely for the addressee. If you are not the intended recipient, any
> disclosure, copying, distribution either whole or partial, is prohibited
> and may be unlawful. In such case, please delete this message and kindly
> notify the sender.
> *Kuala Lumpur Kepong Berhad *
> [image: SEA Best Managed Companies Malaysia]
> <https://clicktime.symantec.com/15tpJCZqbEWv9FauxFMMF?h=oVVGFTlpcjgsdLYWCJZrRsg9HYS5wnn7-H2ee19sPzg=&u=https://www.klk.com.my/>
> notify the sender.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240823/1b1b3d0b/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240823/1b1b3d0b/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240823/1b1b3d0b/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240823/1b1b3d0b/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240823/1b1b3d0b/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240823/1b1b3d0b/attachment-0009.png>
More information about the QGIS-User
