[Qgis-user] Unable to open LAS file in QGIS
    Zoltán Siki
    siki1958 at gmail.com
    Fri Aug 23 10:13:50 PDT 2024
Dear Loke,
open the properties of your point cloud layer and on the symbology tab
change extent only to other option.
[image: image.png]
Probably you use older version of QGIS where this extent only was the
default symbology.
Regards,
Zoltan
Loke Jian Munn via QGIS-User <qgis-user at lists.osgeo.org> ezt írta (időpont:
2024. aug. 23., P, 5:39):
> Hi Team,
> I trying to add point cloud layer(las file) into QGIS but it appear like
> the screenshot below.
> May I know what causing this ?
> Thank you,
> *Loke Jian Munn*
> Information Technology (IT) Department
> *KUALA LUMPUR KEPONG BERHAD*
> Wisma Taiko,
> No. 1, Jalan S.P. Seenivasagam,
> 30000 Ipoh,Perak Darul Ridzuan,Malaysia
> *T    :  *+605 240 8000 (ext. 2443)
> [image: A close up of a sign Description automatically generated]
> <https://clicktime.symantec.com/15tpDKjABDCCmu4drBEZD?h=4-LzQeEUOcKmp7sCwswGafke694l_dZCDQJ4Rb8N8bc=&u=http://www.klk.com.my/>*[image:
> A close up of a sign Description automatically generated]*
> <https://clicktime.symantec.com/15tpJ9vSdpsoBqtZPjdhq?h=bX-LFOj0HrSJV_t-3L_WhMP3i5PRx5AtNBaHlI02C7k=&u=http://www.linkedin.com/company/klkberhad>
> DISCLAIMER: This email and any attachments are confidential and intended
> solely for the addressee. If you are not the intended recipient, any
> disclosure, copying, distribution either whole or partial, is prohibited
> and may be unlawful. In such case, please delete this message and kindly
> notify the sender.
> *Kuala Lumpur Kepong Berhad *
> [image: SEA Best Managed Companies Malaysia] <https://www.klk.com.my/>
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Üdv.
Siki Zoltán
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240823/75cdf340/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240823/75cdf340/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240823/75cdf340/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240823/75cdf340/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240823/75cdf340/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240823/75cdf340/attachment-0009.png>
More information about the QGIS-User
