[Qgis-user] Python code to select polygon at location - SOLVED
Zoltan Szecsei
zoltans at geograph.co.za
Sun Aug 25 22:31:10 PDT 2024
Just by way of finality:
The CRS of the polygon SHP was not what it was purported to be.
I found that the .prj file was invalid when opening it in QGIS - maybe
next time I will first look at the maps I am given, rather than just
dive into python scripting.
All working as expected, now.
Thanks to those who gave ideas to try.
Kind regards,
Zoltan
On 2024/08/25 19:44, Zoltan Szecsei via QGIS-User wrote:
> So as updated plan-of-attack as below.....
>> lyr_poly = QgsVectorLayer(poly_shp, '', 'Ogr') lyr_poly_si =
>> QgsSpatialIndex(lyr_poly.getFeatures(),
>> flags=QgsSpatialIndex.FlagStoreFeatureGeometries) # EPSG:4326 point = QgsPointXY(lon, lat)
>> point_rect = QgsGeometry.fromPointXY(point).buffer(0.001,5).boundingBox()
>> # feature_ids = lyr_poly_si.intersects(point_rect)# intersects wants rectangle requests = QgsFeatureRequest().setFilterFids(feature_ids)
>> # feature_idx = lyr_poly_si.nearestNeighbor(point,10,maxDistance=0.001)
>> requestx = QgsFeatureRequest().setFilterFids(feature_idx)
> For the above code the lists feature_ids and feature_idx are always empty.
> The Longitude and Latitude coords are correct, also for the box
> created from the Point.
> I'd be grateful for any insight on why nothing is found.
> Thanks in advance,
> Zoltan
> On 2024/08/25 16:19, Zoltan Szecsei via QGIS-User wrote:
>> Hi,
>> I'm doing my "once a year need to do something in python with QGIS" :-/
>> Using QGIS 3.38 and PyCharm.
>> I have a SHP file with 28000 polygons.
>> *A SPREADSHEET file with 22000 Points (for which I am making a SHP
>> file and wanting attribute vaues from underlying polygons)*
>> Both in EPSG:4326
>> Without using QGIS processing, what is the quickest way to, for each
>> point 1 by 1, find the underlying polygon and read the attribute
>> field values of that polygon?
>> The code snippet below is far too inefficient - but I cannot find
>> code that selects at XY and benefits from any spatial index on the
>> polygons.
>> lyr_poly = QgsVectorLayer(polygon_shp, '', 'Ogr') point =
>> QgsPointXY(lon, lat) request =
>> QgsFeatureRequest().setFilterRect(lyr_poly.extent()) for
>> feature in lyr_poly.getFeatures(request): geom =
>> feature.geometry() if
>> geom.contains(QgsGeometry.fromPointXY(point)):
>> lyr_poly.select(feature.id()) print(f"Feature with
>> ID {feature.id()} is selected.") break
>> Thanks in advance,
>> Zoltan
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240826/fe7630bc/attachment.htm>
More information about the QGIS-User
