[Qgis-user] Create a polygon with a specific area size
gam17 at riseup.net gam17 at riseup.net
Wed Aug 28 01:36:49 PDT 2024
Hi Nicole,
   if you need regular polygon you can download QAD plugin e try POLYGON
command:
Command: POLYGON
Enter number of sides <5>: 4
Specify center of polygon or [Edge]:
Enter an option [Inscribed in circle/Circumscribed about circle/Area]
<Area>: a
Enter the polygon area in current units <100>: 100.0
if you need rectangle try RECTANGLE command:
Command: RECTANGLE
Specify first corner or [Chamfer/Fillet]:
Specify other corner or [Area/Dimensions/Rotation]: A
Enter rectangle area in current units <100>: 80.0
Calcolate the rectangle dimensions based on [Length/Width] <Length>:
Length
Enter length for rectangle <10>:
gam17
> Dear all,
> I want to create a polygon of a specific size. Currently I am working
> rather "hands on". As long as it is a rectangle and I provide either
> length or width, I can calculate the other one and do a construction
> with the advanced digitizing tool. But is there a way, that I
> construct a more complex polygon and define the area beforehand or
> scale it to a certain area afterwards. To my understanding the polygon
> scaling requires a factor. I cannot scale to a certain area size in
> square meters. Is there another function I haven't found yet?
> I am using QGIS 3.34.4.
> Best regards and thank you so much in advance!
> Nicole Stoffels
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
