[Qgis-user] Adding coordinates to layer
Huesmann, Michaela michaela.huesmann at Stadt-Steinfurt.de
Tue Dec 3 00:17:33 PST 2024
Hello Paddy,
I guess it will work with a Shapefile (or Geopackage) that allows multi-point feature type. Then it works in the same way as if you want to add an additional part to an existing geometry.
You can open the attribute table and select one dataset there. Then activate the map window, zoom in and klick on „add part“ (don’t know the exact english words because i use the German version). This works even if there is no geometry existing yet.
[cid:image001.png at 01DB44D7.74CE0DC0]
Hope it helps you.
Best regards,
Michaela
[Kreisstadt Steinfurt]<http://www.steinfurt.de>
 - 48565 Steinfurt
www.steinfurt.de<http://www.steinfurt.de>
Mit freundlichen Grüßen
im Auftrag
Michaela Huesmann
Geodaten
Fachdienst Tiefbau
Tel.: +49 2552 925 219
Fax:
E-Mail: michaela.huesmann at Stadt-Steinfurt.de<mailto:michaela.huesmann at Stadt-Steinfurt.de>
Bitte denken Sie an die Umwelt, bevor Sie diese E-Mail ausdrucken.
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> Im Auftrag von Pat Brown via QGIS-User
Gesendet: Montag, 2. Dezember 2024 14:09
An: QGIS Mailing List <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
Betreff: [Qgis-user] Adding coordinates to layer
Hi
  I have a csv file with data about various mines. It includes descriptions of locality  but no coordinates. I have added this file to qgis and created a shapefile. I now want to add the coordinates of each mine by searching for its locality on a basemap in qgis then clicking on the map to add the coordinates to the shapefile attribute table.  Is this possible or do I have to search for each location on Google Earth, for example, then write out the coordinates and add them to the attribute table manually?
Thanks
Paddy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241203/0c62e314/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241203/0c62e314/attachment-0001.png>
Type: image/jpeg
Desc: image1272a0.JPG
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241203/0c62e314/attachment-0001.jpe>
More information about the QGIS-User mailing list
