[Qgis-user] topological editing
Andreas Neumann
andreas at qgis.org
Thu Dec 5 00:41:36 PST 2024
Hi Michaela,
I assume both polygons are in the same layer?
Also - the question is: what layers are selected for snapping (second
button). Have you double checked that the layer in question is active?
I generally also advise to enable "Avoid Overlap on Active Layer" (the
button to the right of topological editing) and "self snapping" (the last
button in the toolbar) while working on topological editing.
Finally: which tool did you use when editing the polygons? I am not fully
up-to-date with it's working - but back in the old days it only really
worked with the vertex editor (maybe this was improved meanwhile).
If all of the above still fails - can you share a minimal project (one
small layer with a few features) to help reproduce the issue?
Greetings,
Andreas
On Thu, 5 Dec 2024 at 08:40, Huesmann, Michaela via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hello all,
> I wonder why topological editing does not work in my case.
> I activated the button but I get gaps because the shared vertices do not
> move with the moved vertices.
> QGIS-Version: 3.34.9-Prizren
> Best regards,
> Michaela
> [image: Kreisstadt Steinfurt] <http://www.steinfurt.de>
> - 48565 Steinfurt
> www.steinfurt.de
> Mit freundlichen Grüßen
> im Auftrag
> Michaela Huesmann
> Geodaten
> Fachdienst Tiefbau
> Tel.: +49 2552 925 219
> Fax:
> E-Mail: michaela.huesmann at Stadt-Steinfurt.de
> Bitte denken Sie an die Umwelt, bevor Sie diese E-Mail ausdrucken.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241205/8aafcc9b/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241205/8aafcc9b/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241205/8aafcc9b/attachment-0003.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241205/8aafcc9b/attachment-0001.jpe>
More information about the QGIS-User
