[Qgis-user] Import German population data
    Bernhard Ströbl
    nospam at stroweb.de
    Sat Jul  6 07:13:50 PDT 2024
Hallo Jonathan,
you can import the data as points using the X and Y fields (see manual
[1]) but I suspect you want to display them as raster data
(Hektarraster). Therefore you need to get the Hektarraster 1km grid data
(from here I guess [2]). Each grid cell has an identifier (Field id);
change your Gitter_ID_1km field's contents (or create a new field) to
match the id field and join your csv data to the Hektarraster - done.
[1]
https://docs.qgis.org/3.34/en/docs/user_manual/managing_data_source/opening_data.html#index-9
[2]
https://gdz.bkg.bund.de/index.php/default/geographische-gitter-fur-deutschland-in-utm-projektion-geogitter-national.html
hope this helps
Bernhard
Am 06.07.24 um 14:47 schrieb Jonathan Berschauer via QGIS-User:
> Hi Randy,
> thank you for your quick answer!
> Yes, i tried this, but then i got no layer, which i can select and
> convert into a grid (Vector -> Data Management Tools -> Join attributes
> by location (summary) [or something like that, i use an german ui).
> Or how is the way to create a 1km/1km grid for this data?
> Thanks!
> Am 06.07.24 um 14:39 schrieb Randal Hale via QGIS-User:
>> Did you change the import to use a custom delimiter of semicolon and a
>> geometry definition of "No Geometry"?
>> Randy
>> On 7/6/24 08:23, Jonathan Berschauer via QGIS-User wrote:
>>> Hi everyone!
>>> I want to import German population data (
>>> https://www.statistikportal.de/de/veroeffentlichungen/georeferenzierte-bevoelkerungszahlen ) into QGIS.
>>> The data is in ETRS89/LAEA / EPSG-3035 format.
>>> I modified the CSV, so it looks like this:
>>> Gitter_ID_1km;Zeitraum;Einwohner;X;Y
>>> CRS3035RES1000mN3516000E4281000;2021;1403;4281000;3516000
>>> CRS3035RES1000mN3516000E4282000;2021;1804;4282000;3516000
>>> But when I import it as a layer, no data is shown...
>>> Can anyone help?
>>> Thank you very much!
>>> Jonathan
>>> QGIS-User mailing list
>>> QGIS-User at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User
