[Qgis-user] Import German population data
    Jonathan Berschauer
    dev at tuxjoe.de
    Sat Jul  6 12:38:21 PDT 2024
Hello Bernhard,
this was the perfect tip! Thank you very much, you saved my day!
At first, I struggled with the wrong files (on gdz.bkg.bund.de they
served directly only UTM32), but then i found the whole download
directory at
https://daten.gdz.bkg.bund.de/produkte/sonstige/geogitter/aktuell/
There I located the LAEA files (for example
DE_Grid_ETRS89-LAEA_1km.gpkg.zip ).
Using the field calculator, I was able to create new fields and then
match the data between the different layers.
Thank you very much!
Jonathan
Am 06.07.24 um 16:13 schrieb Bernhard Ströbl via QGIS-User:
> Hallo Jonathan,
> you can import the data as points using the X and Y fields (see manual
> [1]) but I suspect you want to display them as raster data
> (Hektarraster). Therefore you need to get the Hektarraster 1km grid data
> (from here I guess [2]). Each grid cell has an identifier (Field id);
> change your Gitter_ID_1km field's contents (or create a new field) to
> match the id field and join your csv data to the Hektarraster - done.
> [1]
> https://docs.qgis.org/3.34/en/docs/user_manual/managing_data_source/opening_data.html#index-9
> [2]
> https://gdz.bkg.bund.de/index.php/default/geographische-gitter-fur-deutschland-in-utm-projektion-geogitter-national.html
> hope this helps
> Bernhard
> Am 06.07.24 um 14:47 schrieb Jonathan Berschauer via QGIS-User:
>> Hi Randy,
>> thank you for your quick answer!
>> Yes, i tried this, but then i got no layer, which i can select and
>> convert into a grid (Vector -> Data Management Tools -> Join
>> attributes by location (summary) [or something like that, i use an
>> german ui).
>> Or how is the way to create a 1km/1km grid for this data?
>> Thanks!
>> Am 06.07.24 um 14:39 schrieb Randal Hale via QGIS-User:
>>> Did you change the import to use a custom delimiter of semicolon and
>>> a geometry definition of "No Geometry"?
>>> Randy
>>> On 7/6/24 08:23, Jonathan Berschauer via QGIS-User wrote:
>>>> Hi everyone!
>>>> I want to import German population data (
>>>> https://www.statistikportal.de/de/veroeffentlichungen/georeferenzierte-bevoelkerungszahlen ) into QGIS.
>>>> The data is in ETRS89/LAEA / EPSG-3035 format.
>>>> I modified the CSV, so it looks like this:
>>>> Gitter_ID_1km;Zeitraum;Einwohner;X;Y
>>>> CRS3035RES1000mN3516000E4281000;2021;1403;4281000;3516000
>>>> CRS3035RES1000mN3516000E4282000;2021;1804;4282000;3516000
>>>> But when I import it as a layer, no data is shown...
>>>> Can anyone help?
>>>> Jonathan
>>>> _______________________________________________
>>>> QGIS-User mailing list
>>>> QGIS-User at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User
