[Qgis-user] Open another instance of QGIS in Windows
Kobben, Barend (UT-ITC)
b.j.kobben at utwente.nl
Mon Jul 15 03:09:09 PDT 2024
FYI, this does NOT work on Mac (OSX Sonoma 14.5) - it just focusses the already open QGIS instance....
Barend Köbben
On 15/07/2024, 10:10, "QGIS-User" <qgis-user-bounces at lists.osgeo.org> wrote:
That actually works. Yikes. Thats embarrassing :/ :) But Im 100% sure that has not always been the case (at least not at my PC); it used to just bring the already open instance into focus. Anyway, thanks for your super fast response and help :)
On Mon, Jul 15, 2024 at 9:25 AM Nigel Berjak <nigel at s3.co.za<mailto:nigel at s3.co.za>> wrote:
Hi Thomas
Yes. I have many instances opened concurrently with multiple projects. I too lost the file association with the project qgz a long time ago, due to me having multiple versions on my PC.
To achieve this, simply use the Windows (Start menu)/Mac (application menu), search for the QGIS application and version you want to use, then click to open a new instance.
Regards,
Nigel Berjak
0823067330
Please consider the environment before printing this email.
On 2024-07-15 09:19, Thomas Larsen Wessel via QGIS-User wrote:
I want two instances open at the same time, with each their project, so I can copy layer styling from one project to another.
Previously I did the following. Go to Windows Explorer, double click a .qgz file, and that project would open in another instance.
At some point, the file associations were lost, and if I double click the files, it asks what application to use, and QGIS is not even on the list. I think this happened after I installed using osgeo4w-installer, for "Just me" (though I'm not sure).
Anyway, is there anything I can do to open another instance?
Sincerely, Thomas
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240715/054104a0/attachment.htm>
More information about the QGIS-User
