[Qgis-user] Open another instance of QGIS in Windows
Nigel Berjak
nigel at s3.co.za
Mon Jul 15 03:13:31 PDT 2024
Hi
Is this not a setting option for MAC? I don't have a MAC anymore, but
thought that you could change the parameters/settings to allow multiple
instances of an app, as the default setting is a single instance.
Regards,
Nigel Berjak
0823067330
Please consider the environment before printing this email.
On 2024-07-15 12:09, Kobben, Barend (UT-ITC) wrote:
> FYI, this does NOT work on Mac (OSX Sonoma 14.5) - it just focusses the
> already open QGIS instance....
> _-- _
> _Barend Köbben_
> On 15/07/2024, 10:10, "QGIS-User" <qgis-user-bounces at lists.osgeo.org>
> wrote:
> That actually works. Yikes. Thats embarrassing :/ :) But Im 100% sure
> that has not always been the case (at least not at my PC); it used to
> just bring the already open instance into focus. Anyway, thanks for
> your super fast response and help :)
> On Mon, Jul 15, 2024 at 9:25 AM Nigel Berjak <nigel at s3.co.za> wrote:
> Hi Thomas
> Yes. I have many instances opened concurrently with multiple projects.
> I too lost the file association with the project qgz a long time ago,
> due to me having multiple versions on my PC.
> To achieve this, simply use the Windows (Start menu)/Mac (application
> menu), search for the QGIS application and version you want to use,
> then click to open a new instance.
> Regards,
> Nigel Berjak
> 0823067330
> On 2024-07-15 09:19, Thomas Larsen Wessel via QGIS-User wrote:
> I want two instances open at the same time, with each their project, so
> I can copy layer styling from one project to another.
> Previously I did the following. Go to Windows Explorer, double click a
> .qgz file, and that project would open in another instance.
> At some point, the file associations were lost, and if I double click
> the files, it asks what application to use, and QGIS is not even on the
> list. I think this happened after I installed using osgeo4w-installer,
> for "Just me" (though I'm not sure).
> Anyway, is there anything I can do to open another instance?
> Sincerely, Thomas
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user [1]
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user [1]
Links:
[1] https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240715/58b07249/attachment.htm>
More information about the QGIS-User
