[Qgis-user] Speed up loading a project, by postponing fetching WFS features
Emma Hain emma at north-road.com
Mon Jul 22 18:13:36 PDT 2024
Hi Thomas
Have you checked out the Data Source handling section
<https://docs.qgis.org/3.34/en/docs/user_manual/introduction/qgis_configuration.html#data-sources-settings>
in the QGIS document?
Also, you may want to check what Plugins you have loaded and ensure they
are disabled on startup via Plugin Manager/Settings and clicking on the
repository to disable it (uncheck Enabled).
Cheers
Em
On Fri, 19 Jul 2024 at 19:04, Thomas Larsen Wessel via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> I have a project with roughly 30 WFS layers. Most of the layers are
> disabled by default, and I rarely have more than 10 of those layers enabled
> in any session.
> But as far as I can tell, it loads all data from all WFS layers, no matter
> if the layers are enabled or not. Am I right?
> Does this happen in sequence or in parallel?
> It takes 100 seconds from clicking open, until the GUI updates to show the
> loaded project (for the above mentioned project with 30 WFS layers). I
> believe the Internet connection is the bottleneck. Often I'm on a cell
> phone connection, and the load time is much worse.
> Is there anything I can do to make it not load all WFS data right away? Eg
> not load features from any disabled layer, until I actually need it?
> Sincerely, Thomas
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Emma Hain — Product Manager/Senior GIS Analyst
[image: https://north-road.com]
*North Road*
Cartography • Development • Spatial Analysis
*north-road.com* <http://north-road.com>
<https://twitter.com/northroadgeo>
<https://www.linkedin.com/company/north-road-studios>
<https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240723/2ea932dc/attachment.htm>
More information about the QGIS-User mailing list
