[Qgis-user] LAS and LAZ files cannot be opened by this QGIS install.
bitrat
qgis.raro at fastmail.fm
Mon Jul 29 17:07:15 PDT 2024
I installed QGIS specifically to view LIDAR data but, when I tried to open a .LAZ file, I got "LAS and LAZ files cannot be opened by this QGIS install."
Selecting 'More info' gives me:
This QGIS build does not include the PDAL library dependency required for opening LAS or LAZ point clouds.
I installed on Debian from the instructions here:
https://www.qgis.org/resources/installation-guide/#debian-ubuntu
QGIS version: 3.38.0-Grenoble revision 37aa6188bc3
Do I need to build QGAL from source and enable PDAL manually? I _really_ hope not but, if it's the only way, I'll use the instructions here: https://github.com/qgis/QGIS/blob/master/INSTALL.md
Is it possible to limit the interaction with the base OS (eg: install under home dir)?
Any hints and tips appreciated!
Cheers,
bitrat
More information about the QGIS-User
