[Qgis-user] Stopping Embedded Symbols when importing KMLs/Shapefiles [SEC=INTERNAL]
    Alicia Gray
    Alicia.Gray at ventia.com
    Tue Jul 30 13:45:36 PDT 2024
Hi there,
I am a very basic user of QGIS and have just switched to Version 3.34.8. With this version, every time I import a KML or Shapefile it automatically styles it with Embedded Symbols rather than Single Symbols. Is there anyway to change this?
In the example below, I have to change each of the layers on the left to Single Symbol to be able to use my own saved symbols which can become very time consuming when there are hundreds of layers needed at a time.
[cid:image001.png at 01DAE314.9EC89ED0]
[cid:image002.png at 01DAE315.3CA86C20]
[cid:image003.png at 01DAE315.3CA86C20]
Disclaimer
IMPORTANT – This email, and any attachments transmitted with it, may be confidential and privileged. If you are not the intended recipient, you are hereby notified that any dissemination, use or disclosure of this email and any attachments transmitted with it may cause commercial damage to both/either the sender and/or the intended recipient and is strictly prohibited. If you have received this email in error, please contact the sender by return email, do not use or disclose the contents and delete the message and any attachments from your system. Before opening or using attachments, check them for viruses and defects. The Company’s liability is limited to resupplying any affected attachments. Information regarding privacy can be accessed here: http://ventia.com/ckeditor_assets/attachments/39/ventia-privacy-statement.pdf
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240730/6a6d2be1/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240730/6a6d2be1/attachment-0003.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240730/6a6d2be1/attachment-0004.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240730/6a6d2be1/attachment-0005.png>
More information about the QGIS-User
