[Qgis-user] Stopping Embedded Symbols when importing KMLs/Shapefiles [SEC=INTERNAL]
Patrick Dunford enzedrailmaps at gmail.com
Wed Jul 31 14:17:47 PDT 2024
Hello
This information is all part of the styles saved with each layer. You
can copy and paste these styles between layers. These options are found
in the Layers menu (Copy Style / Paste Style).
On 31/07/24 08:45, Alicia Gray via QGIS-User wrote:
> Hi there,
> I am a very basic user of QGIS and have just switched to */Version
> 3.34.8/*. With this version, every time I import a KML or Shapefile it
> automatically styles it with */Embedded Symbols/* rather than */Single
> Symbols/*. Is there anyway to change this?
> In the example below, I have to change each of the layers on the left
> to */Single Symbol/* to be able to use my own saved symbols which can
> become very time consuming when there are hundreds of layers needed at
> a time.
> *Disclaimer*
> IMPORTANT – This email, and any attachments transmitted with it, may
> be confidential and privileged. If you are not the intended recipient,
> you are hereby notified that any dissemination, use or disclosure of
> this email and any attachments transmitted with it may cause
> commercial damage to both/either the sender and/or the intended
> recipient and is strictly prohibited. If you have received this email
> in error, please contact the sender by return email, do not use or
> disclose the contents and delete the message and any attachments from
> your system. Before opening or using attachments, check them for
> viruses and defects. The Company’s liability is limited to resupplying
> any affected attachments. Information regarding privacy can be
> accessed here:
> http://ventia.com/ckeditor_assets/attachments/39/ventia-privacy-statement.pdf
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240801/79cdb6ef/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240801/79cdb6ef/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240801/79cdb6ef/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240801/79cdb6ef/attachment-0005.png>
More information about the QGIS-User mailing list
