[Qgis-user] Visualize object (pipe section) growth
    Andreas Neumann
    andreas at qgis.org
    Wed Jun  5 04:34:43 PDT 2024
Hi Jürgen,
Sure - just use the "Temporal Controller" (menu "View" --> "Panels" -->
"Temporal Controller"). See the QGIS manual section at
https://docs.qgis.org/3.34/en/docs/user_manual/map_views/map_view.html#maptimecontrol
Also have a look at the manual how to set up a layer to prepare it for the
"Temporal Controller":
https://docs.qgis.org/3.34/en/docs/user_manual/working_with_vector/vector_properties.html#temporal-properties
I am sure you will also find plenty of Youtube movies explaining how to set
up the "Temporal Controller" in QGIS.
Hope this helps,
Andreas
On Wed, 5 Jun 2024 at 12:55, Jürgen via QGIS-User <qgis-user at lists.osgeo.org>
wrote:
> Hi there,
> I'm new here and occasionally work with QGIS.
> In my case I would like to visualize the growth of water pipe sections
> over a certain period of time. This means that I have an inventory of pipe
> sections, each with the attribute of its Installation (date, for example
> 2023-02-11). The goal would now be a visualization in which the entire
> network is gradually built up, starting with the oldest line section.
> I have already exported individual pipe sections separately, but I then
> have to import them all by hand to make the increase visible. My question
> is whether there is a way in QGIS to build up the entire inventory
> gradually depending on the attribute values (date).
> I would be happy if someone could help me.
> Cheers Jürgen
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240605/16bbdf69/attachment.htm>
More information about the QGIS-User
