[Qgis-user] Fwd: Export data with tiff and csv files in QGIS 3.36.3
ΣΟΦΙΑ ΤΣΙΤΟΥ
sofitsitou at gmail.com
Tue Jun 11 06:40:29 PDT 2024
Στις Τρί 11 Ιουν 2024 στις 4:38 μ.μ., ο/η ΣΟΦΙΑ ΤΣΙΤΟΥ <sofitsitou at gmail.com>
έγραψε:
> sofitsitou at gmail.com> έγραψε:
>> Dear Richard,
>> Thank you very much for your quick response. I followed this procedure
>> many times but unfortunately I gοt null values. Attached you can find the
>> files that I used (a tiff map and one csv file with the coordinates). I
>> can't find out if there's a problem with my files or something I'm not
>> doing right in the process.
>> Thank you.
>> Warm regards,
>> Sofia Tsitou
>> Στις Τρί 11 Ιουν 2024 στις 3:42 μ.μ., ο/η Richard McDonnell <
>> richard.mcdonnell at opw.ie> έγραψε:
>>> Hi Sofia,
>>> So I will start from the beginning, hopefully I understand your query
>>> properly…
>>> 1. Add your Raster to the Canvas
>>> 2. Using the *Data Source Manager* and *Delimited Text*, I add
>>> the CSV, making sure the Headers, Columns and rows are correct, while also
>>> setting/specifying the X, Y and Z fields (as required)
>>> 3. This will result in a Point Dataset being added to the Canvas,
>>> with the CSV loaded as a temporary layer
>>> 4. In the Processing Toolbox search bar, type “*sample*” and then
>>> select *Sample raster values*
>>> a. *Input layer* set to the Point Dataset
>>> b. *Raster Layer* set to the Raster you want to analyse
>>> c. *Output column Prefix* is handy if you have multiple datasets
>>> you want to sample, as you can change this for each subsequent sample.
>>> d. *Sampled* you can specify a Location for your output dataset,
>>> or you can leave it as a temporary layer until you have carried out all
>>> sampling.
>>> I hope that clarifies things,
>>> Kind Regards,
>>> Richard
>>> Richard McDonnell MSc GIS, FME Certified Professional
>>> *Flood Risk Management - Data Management*
>>> Oifig na nOibreacha Poiblí
>>> Office of Public Works
>>> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
>>> Jonathan Swift Street, Trim, Co Meath, C15 NX36
>>> M +353 87 688 5964 T +353 46 942 2409
>>> https://gov.ie/opw
>>> To send me files larger than 30MB, please use the link below
>>> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
>>> Email Disclaimer:
>>> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
>>> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *S?F??
>>> ?S???? via QGIS-User
>>> *Sent:* 11 June 2024 12:52
>>> *To:* qgis-user at lists.osgeo.org
>>> *Subject:* [Qgis-user] Fwd: Export data with tiff and csv files in QGIS
>>> 3.36.3
>>> Dear QGIS team,
>>> I have two maps in tiff format and coordinates in csv format and I try
>>> through zonal statistics and sample raster values to export the data but it
>>> gives me null values. Could you tell me the steps to extract the data
>>> because I might be making a mistake?
>>> Thank you in advance,
>>> Sofia Tsitou
>>> Tsitou Sofia
>>> Αdjunct Lecturer
>>> Department of Economics
>>> University of Ioannina
>>> Greece
>>> Post Doctoral Fellow
>>> University of Macedonia, Thessaloniki
>>> Greece
>>> Research Fellow
>>> DAISSy Research Group
>>> Hellenic Open University
>>> Greece
>>> e-mail: sofitsitou at gmail.com
>>> Homepage: https://sites.google.com/view/sofiatsitou/home
>>> <https://sites.google.com/view/sofiatsitou/home>
>>> Tsitou Sofia
>>> Αdjunct Lecturer
>>> Greece
>>> Greece
>>> Research Fellow
>>> Greece
>> Tsitou Sofia
>> Αdjunct Lecturer
>> Greece
>> Greece
>> Research Fellow
>> Greece
> Tsitou Sofia
> Αdjunct Lecturer
> Greece
> Greece
> Research Fellow
> Greece
Tsitou Sofia
Αdjunct Lecturer
Greece
Greece
Research Fellow
Greece
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240611/8eb445ce/attachment-0001.htm>
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240611/8eb445ce/attachment-0001.tiff>
More information about the QGIS-User
