[Qgis-user] Rendering shared exterior boundaries of adjacent polygon features
Emma Hain
emma at north-road.com
Wed Jun 19 21:46:15 PDT 2024
Hi Tim
So let's see if I understand you.
- There are 2 polygon layers (green and black)
- These polygon layers sometime overlap
- You wish to show only on the pink line in the below image and not the
green overlapping part?
[image: image.png]
On Thu, 20 Jun 2024 at 11:26, Tim Malloy via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Fellow QGIS Users –
> I’m trying to determine if its possible to have QGIS render the exterior
> boundary of polygon features only once when that boundary is shared with an
> adjacent feature (don’t render overlapping exterior boundaries for both
> polygon features). The data I’m working with is a county parcels layer
> and the symbology I’m using for this layer is a cross hatched line fill
> with a separate component for the outline of the polygons. I’ve tried a
> couple of expressions (examples below) including one geometry generator and
> one data defined override for the stroke width of the boundary line but
> none of them achieves my objective. I’m using QGIS 3.34.7 and my coding
> skills are limited. I feel like I’ve seen this issue covered somewhere
> but have been unable to find a solution after extensive online exploration.
> *Method #1: “*boundary( difference( $geometry, aggregate( 'union',
> 'intersects', $geometry, other_layer := @layer)))” This expression was
> used on the outline component of the symbology described above.
> *Method #2: *“CASE WHEN intersects( $geometry, geom_to_wkt( boundary(
> $geometry ))) THEN 0 ELSE 1 END” Here I switched to using an expression
> on the stroke width of a simple fill, but I got an error message saying
> “Cannot convert to geometry”.
> Any input would be greatly appreciated.
> Tim
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Emma Hain — Product Manager/Senior GIS Analyst
[image: https://north-road.com]
*North Road*
Cartography • Development • Spatial Analysis
*north-road.com* <http://north-road.com>
<https://twitter.com/northroadgeo>
<https://www.linkedin.com/company/north-road-studios>
<https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240620/b99025ff/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240620/b99025ff/attachment-0001.png>
More information about the QGIS-User
