[Qgis-user] Rendering shared exterior boundaries of adjacent polygon features
Zoltan Szecsei zoltans at geograph.co.za
Wed Jun 19 22:06:00 PDT 2024
Also for clarification:
Being a County layer, I would not expect overlapping polygons.
My take is that Tim means "concurrent exterior boundaries" and not
"overlapping exterior boundaries"
*Tim: *What is the reason for wanting only one of the concurrent(?)
boundaries rendered?
Maybe there are other ways to do what you want to.
HTH,
Zoltan
On 2024/06/20 07:46, Emma Hain via QGIS-User wrote:
> Hi Tim
> So let's see if I understand you.
> - There are 2 polygon layers (green and black)
> - These polygon layers sometime overlap
> - You wish to show only on the pink line in the below image and not
> the green overlapping part?
> On Thu, 20 Jun 2024 at 11:26, Tim Malloy via QGIS-User
> <qgis-user at lists.osgeo.org> wrote:
>     Fellow QGIS Users –
>     I’m trying to determine if its possible to have QGIS render the
>     exterior boundary of polygon features only once when that boundary
>     is shared with an adjacent feature (don’t render overlapping
>     exterior boundaries for both polygon features).The data I’m
>     working with is a county parcels layer and the symbology I’m using
>     for this layer is a cross hatched line fill with a separate
>     component for the outline of the polygons.I’ve tried a couple of
>     expressions (examples below) including one geometry generator and
>     one data defined override for the stroke width of the boundary
>     line but none of them achieves my objective.I’m using QGIS 3.34.7
>     and my coding skills are limited.I feel like I’ve seen this issue
>     covered somewhere but have been unable to find a solution after
>     extensive online exploration.
>     *Method #1:“*boundary( difference( $geometry, aggregate( 'union',
>     'intersects', $geometry, other_layer := @layer)))”This expression
>     was used on the outline component of the symbology described above.
>     *Method #2:*“CASE WHEN intersects( $geometry, geom_to_wkt(
>     boundary( $geometry ))) THEN 0 ELSE 1 END”Here I switched to using
>     an expression on the stroke width of a simple fill, but I got an
>     error message saying “Cannot convert to geometry”.
>     Any input would be greatly appreciated.
>     Tim
>     _______________________________________________
>     QGIS-User mailing list
>     QGIS-User at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Emma Hain — Product Manager/Senior GIS Analyst
> emma at north-road.com
> https://north-road.com
> 	*North Road*
> Cartography • Development • Spatial Analysis
> *north-road.com* <http://north-road.com>
> <https://twitter.com/northroadgeo><https://www.linkedin.com/company/north-road-studios><https://www.facebook.com/North-Road-997236690392419/home>
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Zoltan Szecsei GPrGISc 0031
Director, Geograph (Pty) Ltd.
GIS and Photogrammetric Services
Cape Town, South Africa.
Mobile: +27-83-6004028 (Signal, not WhatsApp)
         +974-5058-8729
         +36-20-4808362
www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240620/ea8cc809/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240620/ea8cc809/attachment-0001.png>
More information about the QGIS-User mailing list
