[Qgis-user] problem when opening projects in open instance
Garth Fletcher garth at jacqcad.com
Thu Jun 20 06:59:57 PDT 2024
Just ran into same problem.
I created 2 separate .qgz projects using QGIS 3.34.7 under Mac OSX 10.13.6
I transferred the qgz files to a Windows installation of QGIS 3.34.7 and
only one would open.
The other resulted in the "Unable to unzip file..." error message.
Today I will go back to the site to see the same project saved as .qgs
will open.
My guess is some incompatibility in ZIP handling...
Garth Fletcher
On 6/20/24 Simon Dietmann <dietmann at pgnu.de> wrote:
> Dear list,
> since several weeks I can?t open existing .qgz files from inside an open
>   QGIS instance when they are located on a network drive. The error
> message that appears is "Unable to unzip file: ..."
> There?s no problem when the .qgz is on a local drive or when I open it
> from the windows explorer.
> I?m using latest QGIS Desktop 3.34.7 on  Windows 11.
> Does anyone know about this problem? Any idea for a solution of this
> issue will be appreciated. In case you think it is a bug, I will post a
> report.
Garth Fletcher
More information about the QGIS-User mailing list
