[Qgis-user] problem when opening projects in open instance
Richard Duivenvoorde
rdmailings at duif.net
Thu Jun 20 02:45:39 PDT 2024
I think it is important to know if it is an issue with the actual file (maybe corrupt etc, or maybe locked or so), or the combi of the file + on a network drive.
If you copy that same qgz file to your local disk, is QGIS then able to open it normally?
(if so: then it is network and possibly QGIS related)
Can you try 'unzip/unpack' the file with another 'unzip' program, when it is ON the network drive?
(if so it is QGIS/network related)
Note that a qgz file is a 'normal' zip. Just rename it to .zip to look into it. You will find the old .qgs file. Which actually is an xml file which you can see in an editor.
One of the issues with 'network drives' could be that several people on the same time are writing to it? Not sure if it can get corrupt in this way.... that is why I propose to look into it, IF you can open it as a zip.
HTH
Regards,
On 6/20/24 10:29, Simon Dietmann via QGIS-User wrote:
> Dear list,
> since several weeks I can´t open existing .qgz files from inside an open QGIS instance when they are located on a network drive. The error message that appears is “Unable to unzip file: …”
> There´s no problem when the .qgz is on a local drive or when I open it from the windows explorer.
> I´m using latest QGIS Desktop 3.34.7 on Windows 11.
> Does anyone know about this problem? Any idea for a solution of this issue will be appreciated. In case you think it is a bug, I will post a report.
> Thank you,
> Simon
> i.A. Simon Dietmann
> Projektleiter | Geograph
> PGNU Planungsgesellschaft Natur & Umwelt mbH
> Amtsgericht Frankfurt am Main, HRB 111938;
> Geschäftsführer: Dr. Benjamin Hill, Johannes Christoph Kress, Alexander von Küchler
> Hamburger Allee 45 +++ 60486 Frankfurt am Main
> Durchwahl: +49 69 952964-32 +++ Fax: +49 69 952964-99
> E-Mail: dietmann at pgnu.de +++ Web: www.pgnu.de <http://www.pgnu.de>
>> Diese E-Mail könnte vertrauliche und/oder rechtlich geschützte Informationen enthalten. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail sind nicht gestattet.
>> This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
