[Qgis-user] problem when opening projects in open, instance
Garth Fletcher garth at jacqcad.com
Thu Jun 20 07:27:10 PDT 2024
To further clarify:
I transferred both .qgz files from a USB disk to the user's Documents
directory.
One opened, the other gav the "Unable to unzip file..." error.
So not a network or shared volume issue.
I did not know enough about Windows to try unzipping the .qgz file :-(
Back on the Mac system, both .gqz files on the USB disk opened normally.
So, it seems to me that the possibilities are:
  1) copying error in transferring from USB disk to User's home volume -
unlikely
  2) .ZIP format issue between Mac OSX and Windows
I'll report further after I can test .qgs format on the Windows system.
Garth Fletcher
On 6/20/24 10:08 AM, Garth Fletcher <garth at jacqcad.com> wrote:
> Just ran into same problem.
> I created 2 separate .qgz projects using QGIS 3.34.7 under Mac OSX 10.13.6
> I transferred the qgz files to a Windows installation of QGIS 3.34.7 and
> only one would open.
> The other resulted in the "Unable to unzip file..." error message.
More information about the QGIS-User mailing list
