[Qgis-user] problem when opening projects in open instance
Simon Dietmann dietmann at pgnu.de
Fri Jun 21 00:34:37 PDT 2024
Hi Andrea,
I updated QGIS in the meantime from 3.34.6 to 3.34.7-2, the problem occurred in both versions.
And yes, there was at least one, probably two, Windows updates during the time I had this problem.
I used the Windows standalone .msi installer, and after the installation was complete I removed 3.34.6.
I tried if the problem persists when I use a bare bone minimal profile, with no effect on the issue.
So maybe its possible that the problem is caused by some change in the windows .zip-handling?
Honestly, I have no idea where to investigate....
Thanks for your help,
SImon
-----Ursprüngliche Nachricht-----
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Andrea Giudiceandrea via QGIS-User
Gesendet: Donnerstag, 20. Juni 2024 18:38
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] problem when opening projects in open instance
> Thu Jun 20 01:29:57 PDT 2024
> since several weeks I can´t open existing .qgz files from inside an open QGIS instance when they are located on a network drive. The error message that appears is "Unable to unzip file: ..."
Hi Simon,
you wrote that the issue occurs "since several weeks": did you use the very same QGIS 3.34.7 version even before several weeks ago when the issue didn't occur?
Have the Operative System been updated?
Which installer did you use to install QGIS, the OSGeo4W network installer osgeo4w-setup.exe or the OSGeo4W stand-alone all-in-one installer QGIS-OSGeo4W-3.34.7-2.msi or another one?
Have you tried if the issue occurs also using a new QGIS user profile?
Please read the previous thread in this mailing list about a similar issue https://atpscan.global.hornetsecurity.com/index.php?atp_str=w9z5OrZKw3SbQ8DIEIdqFjKerGMODVJK7F7gyPuektcp44qxlkaOS5N_CFtZX59lPDNjP0mqw3_1rzWJNB38IfGrNbEIY25ekaH_U4GYObwoEEN4NnijeIqLQmrG7lcYWUTlAllB8VZTj7KP9RjpP_q6H6_8xUqLhZ6NkZozEQT07Wk7xGXWHrTLB0RdIC6lj9zRlMyuU3uUowfKOR30zI8_nMpqyCZt0wJk8M3BmLt_1xAXRcIPpjJXk6_4RP_UvAoqrJ887eHGSh3eC0WDo3WBuN8fNmHsH3NLlDAGh3ZmLa19k97d0DG6wEzHBV3D_aL_w4FKkEJesQbjFInoTFCMGFAUDCMP9tt2Yvnd-0GAXEEi6OLPeOVvgd-GIzo6IxvqyE9Wq4LX2YndMyM6OiPwn1zjLgUFqyjgH3zGAosP and the previous issue report about a similar issue  on GitHub https://atpscan.global.hornetsecurity.com/index.php?atp_str=Y4CAoPZI1-kP3f7xUs7HDKcDzcTIlhKs_bEGa_pX_WXBJIUB6QH-U1V7XoH3JGz5ywlBF5DQNI9_Rd3ijWc-6ZOivqR4RN1mUQbQoYfiVYQ-QLmkqeDXhpAogceGIFbADYOXwd7akTnaGVg1s9rCHIPWTvZRNnv2azFJKBCPQPEN9n45qJMyLrNSy7-edU0yG02xRrDJ3zeaikfvWdA2oBb81E2hG1eu_YcyiEXEKXItCn28n5y5e2qk96Q2s2LbLNlq3Dtl754mgC9SDqio7Un8tR4TuLSz8kPYGJma4vG9boupL8Xh7WTLVulOZ1WpOG40BhFINKg2DoSRF7IuvnDDIzo6I6XJsc-AvQV6d96zvCM6OiOKctUGCeEZbfxxNeNMMgOd
Regards.
Andrea
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://atpscan.global.hornetsecurity.com/index.php?atp_str=_L1Atis_avQZI7tN_2cMaY0_STD6VsThtDwxJqZMAVSYNkyUfffNdNajHeWg-wLlewvcLoiS2nLaf1n6YzAJ88XJPDA8vcPcMwdA6lAip0tw64XSxhgloMoXSUFiIa6EjXAubo-llGbV1MST6yx1_Y0Ch7vCAd5R6Q4J06LtFxNJRRspgQxPbak79RTXmSiwpBae-hLlCuRLS88HoadYxAdB1HwJ559RUbOoxbeQWAI4FnZi3cYHxebW067okKLyPkReQfeBEwHOsf-qB3w-RNmeIa4J6FHrH8meFqvHMblAKCFD3-QLh2OeQ0wKNONACWlMdi57KnQEBCBl9ZkTkNSAAowBcOIOdmm3Izo6I0XUhR16oG24_APJbSM6OiPH6G4kqyCLSOgw5xTMs0Nf
Unsubscribe: https://atpscan.global.hornetsecurity.com/index.php?atp_str=wJUKesnNq--mD1-h6IeYFeN22gE4aoino1lcU25Mv7xNTI9lJT-J3Qpe6IBZv_jDTJsB8QHPIH5k9EJ59Ej2Z3cTvFw2IrmS9BgQS1j8SsrYLW-iYvcl0_eiZmj7jABuchYFcP_mRrOEGkxxVwgsOYG5mF3VVD0HXsVViPudy9RF5RnN8Jp5iOJD2cESTIlk-bGXq-M9tI0G2hKtqn5jshcurBMAZpJf_ycOY7uI0N57i-kKBJlCmw6kaIJLkQIpyrbm7ecvpvn86WvN7WSViqaQdn0epQtzi9ZFwE7SYwVvLS8nys5tL_hH2EoMtNIkjk9dHXEDNKVCts-cGOv1cn9cztd7FyPAFtnxIzo6I_XnF-zzx4fnJKEIriM6OiMdpceNXlUS6V9mY1Vw27tV
More information about the QGIS-User mailing list
