[Qgis-user] problem when opening projects in open instance
    Andrea Giudiceandrea
    andreaerdna at libero.it
    Fri Jun 21 04:29:02 PDT 2024
Il 21/06/2024 09:34, Simon Dietmann ha scritto:
> I updated QGIS in the meantime from 3.34.6 to 3.34.7-2, the problem occurred in both versions.
I'm not sure I understood correctly.
Did the issue always occur using QGIS 3.34.6 or didn't it occur using
QGIS 3.34.6 until some weeks ago and then started to occur still using
QGIS 3.34.6 without any QGIS update?
It would be interesting to understand if the starting of the occurrence
of the issue was triggered by a QGIS update or not.
The similar issue described in the previous thread in this mailing list
and in the report already referenced was triggered by an update in the
libzip library used by QGIS and installed by the OSGeo4W installers: the
issue started to occur when libzip was updated from version 1.7.3 (in
3.34.5-1 installer and previous ones) to version 1.10.1 (in 3.34.6-1 e
3.34.7-1 installers).
Such issue was allegedly fixed in 3.34.7-2 installer just downgrading
libzip  to version 1.7.3.
Regards.
Andrea
More information about the QGIS-User
