[Qgis-user] problem when opening projects in open instance - somehow solved
Simon Dietmann dietmann at pgnu.de
Fri Jun 21 06:45:04 PDT 2024
sorry if I wasn´t clear enough. The problem occurred already with QGIS 3.34.6.
But now I am completely puzzled, because without any action by me it seems to have disappeared, and all the QGIS files, no matter if on local or network drive, open from windows explorer as well as from within QGIS....
sorry to have bothered you, but in fact for the first time in about two months, after dozens of attempts, I wasn´t able to reproduce it on the same computer I used all the time....
cheers,
Simon
-----Ursprüngliche Nachricht-----
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Andrea Giudiceandrea via QGIS-User
Gesendet: Freitag, 21. Juni 2024 13:29
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] problem when opening projects in open instance
Il 21/06/2024 09:34, Simon Dietmann ha scritto:
> I updated QGIS in the meantime from 3.34.6 to 3.34.7-2, the problem occurred in both versions.
I'm not sure I understood correctly.
Did the issue always occur using QGIS 3.34.6 or didn't it occur using QGIS 3.34.6 until some weeks ago and then started to occur still using QGIS 3.34.6 without any QGIS update?
It would be interesting to understand if the starting of the occurrence of the issue was triggered by a QGIS update or not.
The similar issue described in the previous thread in this mailing list and in the report already referenced was triggered by an update in the libzip library used by QGIS and installed by the OSGeo4W installers: the issue started to occur when libzip was updated from version 1.7.3 (in
3.34.5-1 installer and previous ones) to version 1.10.1 (in 3.34.6-1 e
3.34.7-1 installers).
Such issue was allegedly fixed in 3.34.7-2 installer just downgrading libzip  to version 1.7.3.
Regards.
Andrea
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://atpscan.global.hornetsecurity.com/index.php?atp_str=lA1YsJaAdnZOlJ4jRmjSGDBMQi4rzLJSoztoJd4GvxUJpER4dSe8WHeqFw6YI8ti8Ymb09kGQ27rWn_oUfr8iQmyoPbFJ6Qar_OHyKtGFC054wME4_nZo23HoY4x9CalpUymW594eV_hOUvxHB-eSthiaZo_AhTd6Hc6zNWFnt4KVfJ3BPAyIVzLoaZfuBX7a7AoHkZm_d-pvIEadk3vjiXDVl18ALT4YPGs1ZasEIvpUeinHKEYDafbNc9GWXdEgO8SrtjnKQchz2vog6WloCezjfoq74HKAe6U46Hzco5Vq2ZbE-l9CCOrE-BUaBK887S5kbQ0uwodgxnlzJf_FJityFiWm9F9RnvuIzo6I0z3XWUWFdqFzAT6viM6OiNXopis24ziaZSsh0Mvkm00
Unsubscribe: https://atpscan.global.hornetsecurity.com/index.php?atp_str=Box8Vi2_c9C1PQzE9SC6ANF5DQjk9nmW9DLXIIjPDCNDlMWUOHV3ZnNXfOYnXHvDMugjFMExWEvoQ5skVOSGtETMbKtvPB0YTGtGdXubzGrzvx_-fvLP5P7naECRxIbcr4iYT4bWFhxmnDsbF0FSZWDuSE0xQeGoMjO7371A15cPvsrvI8D6vZrQaKkEoUKgy6JxRHkINk5aNSLwVvPMb2pIejgs2VNF_CNYPdt1rnydhFKB3dTZM2KDvpamy7BiD6jk-Qggr6DvatklhjZv_NugX3DctdS7VPvRbFBNFWt4Qe1ue0NM4MlkMsyerUZSKE4sUjwEQX-044tym9xGYjVf8DDww6M7h8qXIzo6IzC_a8vL1PooMf6tUCM6OiOyyl_3oPy3hdL39YWH1nCw
More information about the QGIS-User mailing list
