[Qgis-user] [EXTERNAL] Re: OpenID autherntication in QGIS
Nigel Berjak - General
nigel at s3.co.za
Tue Jun 25 05:02:51 PDT 2024
Hi Doug
Are you able to use any non-authenticating ArcGIS servers/WMS/XYZ tiles
etc. on QGIS?
Regards,
Nigel Berjak
Please consider the environment before printing this email.
On 2024-06-25 13:50, Newcomb, Doug wrote:
> Nigel,
> I can't really send you the site, it's a test site from another US
> government agency. I am assuming that it is Open ID ( based on what the
> site owner tells me) .
> It uses login.gov , https://login.gov/ to authenticate via two factor
> authentication ( card/pin) . That authentication is passed to an
> ArcPortal instance on the back end.
> Doug
> From: Nigel Berjak - General <nigel at s3.co.za>
> Sent: Tuesday, June 25, 2024 6:39 AM
> To: Newcomb, Doug <doug_newcomb at fws.gov>
> Cc: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
> Subject: Re: [EXTERNAL] Re: [Qgis-user] OpenID autherntication in QGIS
> Hi Doug
> Can you send through to me the AGOL server link? I know that in
> ArcMap/ArcPro it is slightly different to connect to than QGIS,
> usually. As you mentioned it is OpenID, I assume there are no
> credentials required.
> Regards,
> Nigel Berjak
> On 2024-06-24 14:47, Newcomb, Doug wrote:
> I am trying to connect to an ArcGIS server with QGIS.
> Sent: Friday, June 21, 2024 2:24 AM
> Subject: [EXTERNAL] Re: [Qgis-user] OpenID autherntication in QGIS
> This email has been received from outside of DOI - Use caution before
> clicking on links, opening attachments, or responding.
> Hi Doug
> Please can you clarify. Are you trying to allow users to connect to
> your own server, or trying to connect to an ArcGIS/AGOL server via
> QGIS?
> Regards,
> Nigel Berjak
> On 2024-06-20 20:40, Newcomb, Doug via QGIS-User wrote:
> Trying to connect to ArcGIS Portal behind an OpenID frontend .
> Suggestions anyone? I have read through the detailed directions at
> https://north-road.com/2022/09/16/securely-accessing-arcgis-online-agol-and-enterprise-arcgis-portal-sites-through-qgis-2022-update/
> [1] , but that does not quite seem to fit this situation.
> Doug
> Doug Newcomb - Cartographer
> USFWS
> _We are temporarily lacking a physical office. Electronic and phone
> correspondence is preferred. For snail mail, please use the P.O. Box
> listed below, rather than our former physical address._
> P.O. Box 33726 Raleigh, NC 27636-3726
> New Number (984) 308-0861 doug_newcomb at fws.gov
> _NOTE: This email correspondence and any attachments to and from this
> sender is subject to the Freedom of Information Act (FOIA) and may be
> disclosed to third parties._
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user [2]
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user [2]
Links:
[1]
[2] https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240625/88fe56f9/attachment.htm>
More information about the QGIS-User
