[Qgis-user] [EXTERNAL] Re: OpenID autherntication in QGIS
Newcomb, Doug doug_newcomb at fws.gov
Tue Jun 25 05:04:02 PDT 2024
Yes
Sent: Tuesday, June 25, 2024 8:02 AM
To: Newcomb, Doug <doug_newcomb at fws.gov>
Cc: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Subject: Re: [EXTERNAL] Re: [Qgis-user] OpenID autherntication in QGIS
Hi Doug
Are you able to use any non-authenticating ArcGIS servers/WMS/XYZ tiles etc. on QGIS?
Regards,
Nigel Berjak
Please consider the environment before printing this email.
On 2024-06-25 13:50, Newcomb, Doug wrote:
Nigel,
I  can't really send you the site, it's a test site from another US government agency. I am assuming that it is Open ID ( based on what the site owner tells me) .
It uses login.gov , https://login.gov/ to authenticate  via two factor authentication ( card/pin) . That authentication is passed to an ArcPortal instance on the back end.
Doug
Sent: Tuesday, June 25, 2024 6:39 AM
Hi Doug
Can you send through to me the AGOL server link? I know that in ArcMap/ArcPro it is slightly different to connect to than QGIS, usually. As you mentioned it is OpenID, I assume there are no credentials required.
Regards,
Nigel Berjak
On 2024-06-24 14:47, Newcomb, Doug wrote:
I am trying to connect to an ArcGIS server with QGIS.
Sent: Friday, June 21, 2024 2:24 AM
Subject: [EXTERNAL] Re: [Qgis-user] OpenID autherntication in QGIS
 This email has been received from outside of DOI - Use caution before clicking on links, opening attachments, or responding.
Hi Doug
Please can you clarify. Are you trying to allow users to connect to your own server, or trying to connect to an ArcGIS/AGOL server via QGIS?
Regards,
Nigel Berjak
On 2024-06-20 20:40, Newcomb, Doug via QGIS-User wrote:
Trying to connect to ArcGIS Portal behind an OpenID frontend . Suggestions anyone?  I have read through the detailed directions at https://north-road.com/2022/09/16/securely-accessing-arcgis-online-agol-and-enterprise-arcgis-portal-sites-through-qgis-2022-update/  , but that does not quite seem to fit this situation.
Doug
Doug Newcomb - Cartographer
USFWS
We are temporarily lacking a physical office. Electronic and phone correspondence is preferred. For snail mail, please use the P.O. Box listed below, rather than our former physical address.
P.O. Box 33726 Raleigh, NC 27636-3726
New Number (984) 308-0861 doug_newcomb at fws.gov<mailto:doug_newcomb at fws.gov>
NOTE: This email correspondence and any attachments to and from this sender is subject to the Freedom of Information Act (FOIA) and may be disclosed to third parties.​
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240625/bee393a7/attachment.htm>
More information about the QGIS-User mailing list
