[Qgis-user] Digitizing annoyance
Gordon Wakelin-King gwk at gbenergy.com.au
Mon Mar 18 15:58:29 PDT 2024
I read the following in the manual
“Depending on the format of the data and the GDAL library built with your QGIS version, some tools may not be available.”
Is the attribute table you wish to edit  reading from a CSV or similar? I would Save_as a shapefile or geopackage layer and work from that.
Cheers
Gordon Wakelin-King
Sent: Tuesday, March 19, 2024 2:20 AM
To: Gordon Wakelin-King <gwk at gbenergy.com.au>
Subject: Re: [Qgis-user] Digitizing annoyance
the pencil will not become active.  i can see it, but i can make no edits.
On Sun, Mar 17, 2024 at 9:31 AM Gordon Wakelin-King <gwk at gbenergy.com.au<mailto:gwk at gbenergy.com.au>> wrote:
Right click on the layer in the menu and select Attribute table, then click the little pencil at top left of the table's toolbar. You can now edit on the attribute table manually or by expressions.
Good luck
Get Outlook for Android<https://aka.ms/AAb9ysg>
From: QGIS-User <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> on behalf of Byron Veilleux via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
Sent: Saturday, March 16, 2024 1:29:23 AM
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org> <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
Subject: [Qgis-user] Digitizing annoyance
When I am digitizing simple contours, I am finding that after editing and saving the layer, I end up with duplicate contours, one of which I must delete or the labels look silly.  Any idea why this might be happening?
Is there a way to edit an attribute table,  I want to change or delete a few points or labels without having to do it in the csv file
Byron Veilleux, MSc. P.Geo
Conjugate Geologic Services Limited
Calgary, Alberta Canada
byron at conjugategeo.com<mailto:byron at conjugategeo.com>
Cell:4037108414
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240318/c13df1e6/attachment.htm>
More information about the QGIS-User mailing list
