[Qgis-user] Digitizing annoyance
    Byron Veilleux
    byron at conjugategeo.com
    Mon Mar 18 17:22:46 PDT 2024
I will try that.
On Mon, Mar 18, 2024 at 4:58 PM Gordon Wakelin-King <gwk at gbenergy.com.au>
wrote:
> I read the following in the manual
> “Depending on the format of the data and the GDAL library built with your
> QGIS version, some tools may not be available.”
> Is the attribute table you wish to edit  reading from a CSV or similar? I
> would Save_as a shapefile or geopackage layer and work from that.
> Cheers
> *Gordon Wakelin-King*
> *From:* Byron Veilleux <byron at conjugategeo.com>
> *Sent:* Tuesday, March 19, 2024 2:20 AM
> *To:* Gordon Wakelin-King <gwk at gbenergy.com.au>
> *Subject:* Re: [Qgis-user] Digitizing annoyance
> the pencil will not become active.  i can see it, but i can make no edits.
> On Sun, Mar 17, 2024 at 9:31 AM Gordon Wakelin-King <gwk at gbenergy.com.au>
> wrote:
> Right click on the layer in the menu and select Attribute table, then
> click the little pencil at top left of the table's toolbar. You can now
> edit on the attribute table manually or by expressions.
> Good luck
> Get Outlook for Android <https://aka.ms/AAb9ysg>
> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> on behalf of Byron
> Veilleux via QGIS-User <qgis-user at lists.osgeo.org>
> *Sent:* Saturday, March 16, 2024 1:29:23 AM
> *To:* qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
> *Subject:* [Qgis-user] Digitizing annoyance
> When I am digitizing simple contours, I am finding that after editing and
> saving the layer, I end up with duplicate contours, one of which I must
> delete or the labels look silly.  Any idea why this might be happening?
> Is there a way to edit an attribute table,  I want to change or delete a
> few points or labels without having to do it in the csv file
> Byron Veilleux, MSc. P.Geo
> Conjugate Geologic Services Limited
> Calgary, Alberta Canada
> Cell:4037108414
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240318/94199c4a/attachment.htm>
More information about the QGIS-User
