[Qgis-user] Command for raster reprojetion from geodetic to cartesian coordinates
chris hermansen clhermansen at gmail.com
Fri May 10 09:01:12 PDT 2024
Alexandre and list,
On Fri, May 10, 2024 at 5:50 AM Alexandre dos Santos via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Dear Member,
> I have a Global raster of elevation (''wc2.1_10m_elev.tif) and I'd like
> to reprojection from (+proj=longlat +datum=WGS84 +no_defs +ellps=WGS84
> +towgs84=0,0,0) to ("+proj=laea +x_0=0 +y_0=0 +lon_0=0 +lat_0=0"). Is
> there some command for this?
In the online manual in section  28.2.5.3 you will find the usage of the
"warp" command which is used to reproject raster layers.
https://docs.qgis.org/3.34/en/docs/user_manual/processing_algs/gdal/rasterprojections.html#warp-reproject
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240510/205140cd/attachment.htm>
More information about the QGIS-User mailing list
