[Qgis-user] Advance Digitising Tools- compass bearings
    Greg Troxel
    gdt at lexort.com
    Fri May 17 05:48:46 PDT 2024
Philip Ryan via QGIS-User <qgis-user at lists.osgeo.org> writes:
> Hello,
> I am trying to digitise a series of old gold lease "portion plans"
> produced in the 1880s in Australia by a mining surveyor using a
> compass and chain. The data for each gold lease includes a table of 1)
> compass bearings in degrees and 2) distance measurements in links (0.2
> m) for each vertex of the lease polygon (mostly a rectangle or
> trapezoid but sometimes more complex).
>From a US perspective, a link being 0.2 m is interesting.  Here we have
a 66 foot chain with 100 links.  That turns out to be 201mm, something I
had never realized.  I wonder if your data is in Gunter's chains, or in
some metricified version where a link is really 0.2m.   Sort of like how
the kids in Europe drag race in "metric quarter miles" of 400m, or so we
imagine in the US.
  https://en.wikipedia.org/wiki/Gunter%27s_chain
What you are trying to do (abstracting "gold lease" to "survey plan
without global coordinates) seems common, and I have not really
understood the best way to proceed.
I think there are two parts:
  Capturing the survey plan in a local coordinate system *for that plan*
  which is going to be in distances at ground level (vs reduced to the
  ellipsoid) and oriented to perceived local magnetic north as of the
  date of survey (or for more modern plans, adopting a basis of bearings
  of some previous regional plan).
  Transforming that local coordinate system to global coordinates.  This
  is a scale factor, perhaps left at 1 if there's no real evidence
  otherwise, translation and orientation.
For the second part, it would be great to have a tool that lets you
match up both coordinates and stores them in a control file you can
edit, and produces an object you can use with proj.  The georeferencer
almost does this, but apparently only for images, and it's a little
unclear to me about storage and redoing.
More information about the QGIS-User
