[Qgis-user] Advance Digitising Tools- compass bearings
Alessandro Pasotti
apasotti at gmail.com
Fri May 17 06:06:44 PDT 2024
Hi Philip,
Is this what you are looking for?
https://github.com/qgis/QGIS/pull/53061
On Fri, May 17, 2024 at 3:50 AM Philip Ryan via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hello,
> I am trying to digitise a series of old gold lease "portion plans"
> produced in the 1880s in Australia by a mining surveyor using a compass and
> chain. The data for each gold lease includes a table of 1) compass
> bearings in degrees and 2) distance measurements in links (0.2 m) for each
> vertex of the lease polygon (mostly a rectangle or trapezoid but sometimes
> more complex).
> The Advance Digitizing Tools would seem to be ideal for this data except
> for the angle measure (a) which I can't input as a compass bearing (0-360
> deg). The current settings with 90 deg E as the zero makes conversion of
> compass bearings very tedious.
> Is it possible to change the angle variable (a) to a compass bearing?
> Regards,
> Phil Ryan
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240517/df90524b/attachment.htm>
More information about the QGIS-User
