[Qgis-user] Raster reverts to old Min/Max
Drew French
fullboarfarm at gmail.com
Tue May 28 10:05:09 PDT 2024
Thanks Richard, I will check that out. On a relatively unrelated note, on a
raster, if I go to Symbology window, click on Transparency, and accidently
leave the Transparency Band option on Band 1, the raster will appear half
transparent regardless of what you do in the Symbology tab. I was flummoxed
for a while until I found that out.
On Tue, May 28, 2024 at 9:45 AM Richard McDonnell <richard.mcdonnell at opw.ie>
wrote:
> Hi Andrew,
> One probable solution is to save the new style as the default, for the
> Layer.
> Kind Regards,
> Richard
> Richard McDonnell MSc GIS, FME Certified Professional
> *Flood Risk Management - Data Management*
> Oifig na nOibreacha Poiblí
> Office of Public Works
> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
> Jonathan Swift Street, Trim, Co Meath, C15 NX36
> M +353 87 688 5964 T +353 46 942 2409
> https://gov.ie/opw
> To send me files larger than 30MB, please use the link below
> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
> Email Disclaimer:
> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Drew
> French via QGIS-User
> *Sent:* 28 May 2024 15:27
> *To:* QGIS List <qgis-user at lists.osgeo.org>
> *Subject:* [Qgis-user] Raster reverts to old Min/Max
> Hi all,
> I have two DEMs, one is the whole USA, the other is a watershed. They
> obviously have two different raster Min/Max levels, based on elevation.
> When I adjust the watershed DEM to my liking, I then right click, copy the
> style, and right click the USA DEM to paste the style. So far, so good, I
> did this a thousand times in the past without a problem. Now, though, when
> I adjust anything in the USA DEM, it reverts right back to the old Min/Max.
> Anybody else have this issue and what do you think is going on?
> Using 3.34.1 Prizren
> Andrew French
> (715) 986-8088
Andrew French
(715) 986-8088
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240528/fe68f48a/attachment.htm>
More information about the QGIS-User
