[Qgis-user] [QGIS-Developer] lack of conflation tools
Vincent Picavet vincent.ml at oslandia.com
Fri May 31 02:22:20 PDT 2024
Geospatial data conflation is not an easy task, and usually depends on :
- the input data
- desired output
- semantics
- conflation based mainly on semantics( / attribute data ), topology or purely geometric
Note that semantic and topology-based methods are much more robusts than geometry-based ones.
In any case, there is no magic workflow and the method has to be adapted to the specific context.
I contributed to an implementation based on PostGIS quite a long time ago :
https://docplayer.fr/8718145-Appariement-de-graphes-de-reseau-avec-postgis.html ( in french ).
There could be some generic algorithms which could be made available in QGIS processing to ease creation of workflows for conflation ( e.g. node fingerprints, geometry local correspondance search  ).
Get in touch if you are interested in developing some.
Vincent
On 30/05/2024 11:46, PIERRE Sylvain via QGIS-Developer wrote:
> Hi devs and  qgis power users,
> After investigating I can arg that there’s a lack of conflation tools in QGIS like such existing for Esri  :
> https://proceedings.esri.com/library/userconf/proc17/tech-workshops/tw_513-105.pdf
> Is there some plan or something I miss for doing such task in QGIS ?
> Thanks
> Sylvain PIERRE**
> Chef de projet système d’information
> Direction des Systèmes d’Information et du Développement Numérique
> Service Projets et Ingénierie Numérique
> *Collectivité européenne d’Alsace*
> Tél : 03 88 76 68 88
> sylvain.pierre at alsace.eu <mailto:sylvain.pierre at alsace.eu>
> www.alsace.eu <http://www.alsace.eu>
> facebook <http://www.facebook.com/toutelalsace>twitter <http://www.twitter.com/toutelalsace>insta <http://www.instagram.com/toutelalsace>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240531/c64d5d43/attachment.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240531/c64d5d43/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240531/c64d5d43/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240531/c64d5d43/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240531/c64d5d43/attachment-0002.png>
More information about the QGIS-User mailing list
