[Qgis-user] TreeEyed Plugin module error
Pam Bond
pam at gowestgis.com
Fri Nov 1 15:39:08 PDT 2024
I am using QGIS 3.28.9-Firenze on a Windows 11 machine. When I install the
TreeEyed plugin (https://treeeyed.readthedocs.io/en/latest/index.html), it
prompts me to install additional Python packages. I say 'yes' and when it
completes the Log file sshows it was successful but, then when I click on
the TreeEyed plugin icon to run it, it again says 'Additional python
packages are required to use this plugin. I say 'yes' again and then it
fails and I get the following messages in the Log file:
2024-10-31T19:57:43 WARNING checking packages
2024-10-31T19:57:43 CRITICAL Dependencies could not be imported
2024-10-31T19:57:43 CRITICAL No module named 'gdown'
2024-10-31T19:57:48 WARNING Installing additional packages canceled
2024-10-31T20:02:22 WARNING checking packages
2024-10-31T20:02:22 CRITICAL Dependencies could not be imported
2024-10-31T20:02:22 CRITICAL No module named 'gdown'
If I look in the TreeEyed plugin dependencies folder
(C:\Users\xxx\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\tree_eyed\dependencies),
there are folders named 'gdown' and 'gdown-5.2.0.dist-info'.
In the gdown folder:
[image: gdown_folder]
<https://private-user-images.githubusercontent.com/150748626/382161727-9f4e997d-f272-40d3-a8ca-fbef5f82c0c5.jpg?jwt=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiJnaXRodWIuY29tIiwiYXVkIjoicmF3LmdpdGh1YnVzZXJjb250ZW50LmNvbSIsImtleSI6ImtleTUiLCJleHAiOjE3MzA1MDA5ODgsIm5iZiI6MTczMDUwMDY4OCwicGF0aCI6Ii8xNTA3NDg2MjYvMzgyMTYxNzI3LTlmNGU5OTdkLWYyNzItNDBkMy1hOGNhLWZiZWY1ZjgyYzBjNS5qcGc_WC1BbXotQWxnb3JpdGhtPUFXUzQtSE1BQy1TSEEyNTYmWC1BbXotQ3JlZGVudGlhbD1BS0lBVkNPRFlMU0E1M1BRSzRaQSUyRjIwMjQxMTAxJTJGdXMtZWFzdC0xJTJGczMlMkZhd3M0X3JlcXVlc3QmWC1BbXotRGF0ZT0yMDI0MTEwMVQyMjM4MDhaJlgtQW16LUV4cGlyZXM9MzAwJlgtQW16LVNpZ25hdHVyZT05NWFiZjI3Y2JhYTQ2MjE3NjhlYmIyM2ExYTVhOTgxZTc0YmUzODI5MWVlMzZjYzY1M2M2NjAwNzBmMjU1MzI1JlgtQW16LVNpZ25lZEhlYWRlcnM9aG9zdCJ9.m1jvTqud0mCM68cCGgsB-tz6Up7sA1LUnyUZdaL_8Ws>
In the gdown-5.2.0.dist-info folder:
[image: gdowndist_folder]
<https://private-user-images.githubusercontent.com/150748626/382161873-bc72eda1-d665-4cf8-a890-1de40378489c.jpg?jwt=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiJnaXRodWIuY29tIiwiYXVkIjoicmF3LmdpdGh1YnVzZXJjb250ZW50LmNvbSIsImtleSI6ImtleTUiLCJleHAiOjE3MzA1MDA5ODgsIm5iZiI6MTczMDUwMDY4OCwicGF0aCI6Ii8xNTA3NDg2MjYvMzgyMTYxODczLWJjNzJlZGExLWQ2NjUtNGNmOC1hODkwLTFkZTQwMzc4NDg5Yy5qcGc_WC1BbXotQWxnb3JpdGhtPUFXUzQtSE1BQy1TSEEyNTYmWC1BbXotQ3JlZGVudGlhbD1BS0lBVkNPRFlMU0E1M1BRSzRaQSUyRjIwMjQxMTAxJTJGdXMtZWFzdC0xJTJGczMlMkZhd3M0X3JlcXVlc3QmWC1BbXotRGF0ZT0yMDI0MTEwMVQyMjM4MDhaJlgtQW16LUV4cGlyZXM9MzAwJlgtQW16LVNpZ25hdHVyZT03NjQ3MjBhMjZjYTMwNjdjOGUxYzhmNTJjOTAyMjM5Yjc0NmE4OGIwZjAyNzBiZDMzY2I5Zjg3YmIwYzU4NGE2JlgtQW16LVNpZ25lZEhlYWRlcnM9aG9zdCJ9.32OxhQDXItkZviNb9JbfLzzW-hgOIJ1GqRcC215v9Ic>
Has anyone else experienced this issue and figured out how to resolve it?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241101/b855ea1a/attachment.htm>
More information about the QGIS-User
