[Qgis-user] Cutting Virtual raster into tiles
    Richard McDonnell
    richard.mcdonnell at opw.ie
    Mon Nov  4 03:39:10 PST 2024
Hi Bernie,
GdalWarp, or any other Raster manipulation, will indeed will indeed be resampling pixels, when you clip the raster it then tries to fit, align your pixels into your clipped extents.
Could I suggest that you first generate a GeoTiff from your VRT. You can again use GDAL Warp, but the important thing would be to:
1.       Set Georeferenced Extents, using the Calculate from Layer option and set it to your 10km grid File.
2.       Additional command-line… just type –tap this will align all pixels in the output to the crs/grid.
What the above should do is output a TIFF aligned both in extents and pixels to that of your output grid.
I hope that helps, or at least gives you some idea on how you might proceed.
Kind Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
Flood Risk Management - Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Bernie Connors via QGIS-User
Sent: 01 November 2024 22:39
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Cutting Virtual raster into tiles
Hello,
        I have created a virtual raster of DEM data covering approximately 72,000 km^2.  The DEM has a 1 metre pixel.  The source for the virtual raster is about 95 geoTIFF files with irregular shapes.  I have a SHP file with a 10 km grid of tiles, with a total of 853 polygons (see image below).  I am trying to cut the virtual raster into 853 tiles based on the SHP file.  Each tile will be 10 km x 10 km.  The tiles in the SHP file are exactly 10,000 metres x 10,000 metres.  So I expect the DEM tiles to be exactly 10,000 pixels x 10,000 pixels.  However, when I run the QGIS Easy Raster Splitter plugin the output geoTIFF DEM tiles are 9,999 pixels x 10,000 pixels.  I have checked all 853 tiles and they are all 9,999 x 10,000 pixels.  Here are the first few lines reported by gdalinfo.
Driver: GTiff/GeoTIFF
Files: nb_2015_16_18_dem_2460000_7480000.tif
Size is 9999, 10000
Coordinate System is:
        Here is an image of the 1 metre gap between the 10 km tiles.  I set the scale in QGIS to 1:1,000 for this image.
[cid:image001.png at 01DB2EAB.C6BA1210]
        These 1 pixel (1 metre) gaps appear as vertical gaps with a 10 km spacing when several tiles are displayed together.
        Both the SHP file and the source DEM GeoTIFFs all use the same projected coordinate system - EPSG 2953.  The  Easy Raster Splitter plugin uses gdalwarp in the background.  I suspect gdalwarp is doing some kind of reprojection when it calculates the intersection between the individual tiles in the SHP and the source VRT.  But I am unsure.  Does anybody have a suggestion?
[cid:image003.jpg at 01DB2EAB.C6BA1210]
Thanks,
Bernie.
Bernie Connors, P.Eng
B.Sc Geodesy & Geomatics Engineering
Fredericton, NB
bernie.connors at unb.ca<mailto:bernie.connors at unb.ca>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241104/e7038e95/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241104/e7038e95/attachment-0001.png>
Type: image/jpeg
Desc: image003.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241104/e7038e95/attachment-0001.jpg>
More information about the QGIS-User
