[Qgis-user] Verifying QGIS
    Andreas Neumann
    andreas at qgis.org
    Mon Nov  4 23:16:07 PST 2024
Hi David,
Tips for first launch (MacOS only)
<https://www.qgis.org/download/#tips-for-first-launch>
After installing QGIS, the first launch attempt may fail due to Apple’s
security framework.
*For macOS Sonoma and earlier:* To enable QGIS, command-click on its icon
in your Applications folder and select *Open* in the context menu. A
confirmation dialog will display where you need to click the *Open* button
again. This only has to be done once.
*For macOS Sequoia and newer:* To enable QGIS, command-click its icon in
your Applications folder and select *Open* from the context menu. A warning
dialog will appear; click the *Done* button. Next, navigate to *System
Settings > Privacy & Security* and scroll to the *Security* section. You
should see a message stating that *“QGIS” was blocked to protect your Mac*.
Click *Open Anyway*. A confirmation dialog will appear; click *Open Anyway*
Apparently, it is not easy to correctly sign an Open Source software built
on top of many other Open Source libraries (geos, gdal, proj) etc. from
different developer sources.
However, the QGIS devs are trying to find a solution for this known
problem. Until then, please follow the steps listed above.
Andreas
On Tue, 5 Nov 2024 at 08:05, David Saldivar via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> I have been having trouble with getting QGIS up and running. I am able to
> get it downloaded however it says that it can not be verified. I have
> attached a screenshot of this below
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241105/239fdc49/attachment.htm>
More information about the QGIS-User
